changed out 88 civic engine no start
Old Mar 4, 2014 | 09:45 AM
dalliboy's Avatar
Default changed out 88 civic engine no start
changed out eng. w/ a good used one it almost wanted to start but never has is there any marks I should of lined up on the clutch side that I don't know about
Old Mar 4, 2014 | 10:51 AM
m4xwellmurd3r's Avatar
Not starting as in not running?
Make sure your firing order is correct
Old Mar 6, 2014 | 09:34 PM
slowcivic2k's Avatar
Default Re: changed out 88 civic engine no start
Does the engine crank with the same speed every time? Check your grounds, including thermostat and starter.
Did the old engine crank?
Old Mar 6, 2014 | 10:00 PM
He said it almost starts so im wondering if he accidentally wired the plug wires backwards. I did that once and it actualky fired up and ran for a very short time back firing like a gun.
Its easy to assume that its 1 2 3 4 when looking at the bay when its actually 4 3 2 1
Old Mar 7, 2014 | 01:09 AM
n*werk's Avatar
let start with the basic, what engine did you swap? what year did it come from? what ecu are you using? the more info we can get would be great.
feret
14
Nov 21, 2013 08:36 AM
munchlax
Jun 16, 2011 06:40 AM
Kongo69
Honda Civic (2001 - 2005)
Jul 14, 2008 01:27 PM
vincsk2003
Feb 21, 2008 07:53 AM
