Anyone running 8x15 rims on the EG civic?
Old Mar 3, 2014 | 01:04 PM
strigga's Avatar
Default Anyone running 8x15 rims on the EG civic?
If u run 8x15 wheels, could you post a picture of it with dimension and offset?
thank you
Old Mar 3, 2014 | 02:55 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Anyone running 8x15 rims on the EG civic?
This is the tech section. We do actual technical threads here. What you want is not technical, at all.
You're looking for either Wheel and Tire or Appearance. Try again.
Old Mar 3, 2014 | 03:36 PM
B_Swapped93's Avatar
15x8** cmon an 15 inch wide wheel ? offset plays into things also I have 15x8 rota slips +35 fit fine on my DC2.
Old Mar 20, 2014 | 09:36 AM
strigga's Avatar
sorry, in europe we say the width first - i meant 15x8.
thanks will post it in an other section
Old Mar 20, 2014 | 11:11 AM
P-M-B,93EXsedan's Avatar
I am interested in a solid answer for this too, not "offset around 25 maybe?"
strigga, ppl also prefer if you give specific details about the car in the first post, 2 or 4 door, exact year, etc
my civic is a 93 EX 4 door. I want the same exact size wheels as the OP
Old Mar 20, 2014 | 03:35 PM
strigga's Avatar
I'd like to know which 8x15 wheels fit without rolling fenders or without camber kits. Which offset is good for that?
Civic EG Hatchback 94'
Old Mar 20, 2014 | 03:59 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I would be nice and post but to lazy. In my signature is the link. 15x8 +25 205/50/15 z1 star spec's with natural chamber. Fenders were rolled and pulled.
Old Mar 20, 2014 | 09:55 PM
Strigga that was the same answer I got when I asked literally the same question, bolt-on-only wheels.
apparently 15x7 is the limit for our chassis without messing around with the body. IV got other problems to fix first but I'm probably gonna end up modifying the wheel wells despite not wanting to. I'd really like to keep the car original since thats the condition I got it, at this point I'm leaning toward going all out full restoration, engine swap w/ stroked out block and maybe even a turbo.
Old Mar 21, 2014 | 09:45 AM
It really depends on the width of tire your running. My Enkei 15x7 +36 with same 205 star specs still needed the lip rolled.
Its real easy to measure and see exactly what fitment you want. Remove wheel and compress LCA and suspension to ride height, then measure off of the hub. Center of the wheel is 0 offset. + to front of rim, - to back. If a wheel says 15x7, it is about 8 inches wide at the outer most edge.
Easiest way(without fender roller) is use small base ball bat and roll the lip. Then use a phone book between the wheel and fender. Lower the suspension to push the tire into the fender well. x4 Key to pulling is gradually working the fender wider and not just all at once. A heat gun will help protect the paint
Old Mar 22, 2014 | 05:35 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
15x8 Rota RB, +30 offset. 205-50/15 Falken ZE912. Lowered 1.5-1.75 inches. No rub after removing black trim from rear fenderwells
EG-SIXV-TEC
Jun 30, 2012 08:48 PM
BLeSR
27
Aug 18, 2009 03:01 AM
hondaon18's
Apr 29, 2009 08:57 AM
b16_egr
Apr 21, 2007 10:43 AM
stormy
Mar 31, 2005 01:01 PM
