help
hey guys
i have honda civic 2007 exi 4 doors with engine 1.8 vtec automatic transmission i just want your help and suggestion to add some horsepower i just installed cold charge intake simota but it doesn't make sense can you suggest me what to install to add some power but without using turbo
also any one have any idea if i can installing the ECU of civic type R on my civic? the to remap it or chip tuning ?
thanks in advance
thanks in advance
You can do a little searching as some of this has been answered already...
but honestly if you want power you should of got an Si...any part you put on won't yield you much power. The engine you have is not designed for high power!
Also the Type-R ecu will not work on your engine as it's for a different engine. If you want to do ecu management I would get Hondata instead... but even that wont really yield you much.
Sometimes you need to realize you can't perform a miracle when you have the wrong platform!
