Oil pump
Old Mar 3, 2014 | 05:43 AM
Aaronw93's Avatar
Default Oil pump
So I have a 92 Honda civic with a d16y8 in it as th other day I was goin down the road and when I stopped the oil light came on and started to flash a lil bit but when I took off it when off and would stay off until I stopped then it would come on and flash again wht could this be?
Old Mar 3, 2014 | 05:47 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Oil pump
Most likely your bearing or pump clearances are much too wide due to wear. Either way this is the Engine Management Section - as in using a laptop to tune the vehicle... and not your normal tech section. You should have posted in the 92-00 Civic section.
Old Mar 3, 2014 | 05:57 AM
Aaronw93's Avatar
Ok what do u mean the clearances r too
Old Mar 3, 2014 | 06:50 AM
DO IT ON ALL FOURS
When bearing clearances are too loose from wear, oil is essentially pouring out to be dramatic. The loss of this restriction from proper clearances will result in loss of pressure and will be more noticed at idle when the volume isn't there from the pump. I don't know how to put it any more basic than that.
Old Mar 3, 2014 | 07:00 AM
motoxxxman's Avatar
aka: your engine needs to be rebuilt. the bearings and/or oil pump are worn out beyond spec. continuing to drive the car as it sits right now will soon lead to catastrophic failure.
Old Mar 3, 2014 | 11:51 AM
F22Master's Avatar
Make sure you have enough oil in the engine first... Check the dipstick.
Old Mar 3, 2014 | 01:52 PM
Aaronw93's Avatar
It has oil and someone told me it could just be the oil pressure sensor went bad or tht the oil pump is goin out is either one if these things possibly what's goin on?
Old Mar 3, 2014 | 03:57 PM
DO IT ON ALL FOURS
Oil pressure switches don't typically fail intermittently. They usually stick open or closed. It is just a switch after all. Other than that have you even read what you are being told? I think you are beyond help.
Old Mar 4, 2014 | 03:42 PM
98vtec's Avatar
moderator emeritus
take your car to a respected local mechanic and have them check it out.
cityofcaterpillars
Oct 1, 2017 06:26 PM
88turdbucket
Dec 20, 2008 10:27 AM
fryguy190
10
Aug 31, 2008 08:13 PM
LordAphotic
Apr 12, 2006 11:32 AM
slipperyduck
Feb 16, 2006 09:52 AM
