Rev limiter problems.
Old Mar 3, 2014 | 02:31 AM
Loy's Avatar
Loy
Default Rev limiter problems.
Does anyone happen to know when the rev limiter is suppose to kick in on a 96 Accord w/ 4 cyclinder vtec? I cannot go past 3, 250 rpm without it knocking it back down. When I bought the car I did a timing belt job on it. The check engine light came after that and the code was for the crank sensor. I rechecked the timing on it and it is exactly where it should be. Is this sensor the cause of my problem or is there something else going on?
Old Mar 3, 2014 | 10:39 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Rev limiter problems.
crank sensor is an obd2 thing. yes its broken if thats the code and yes that will put the car in limp mode
it should top out from ecu around 6-7k rpms
Old Mar 3, 2014 | 11:45 PM
holmesnmanny's Avatar
could be dirt and grime on the pulley or the sensor preventing pickup or maybe the connector isn't plugged in all the way
Old Mar 22, 2014 | 04:34 PM
Loy's Avatar
Loy
The sensor did have some black buildup on it when I did the timing belt job so I wiped it off. However it did get wet when I pulles the water pump. Could this have anything to do with it? Or when removed it to clean it could it have gotten out of whack with the crank pulley?
ian1006
Mar 23, 2018 06:08 AM
tougeem2
Nov 15, 2011 05:39 AM
2000siturboR
Nov 6, 2009 03:29 PM
pos94accord
Jan 25, 2009 05:29 PM
lude98SH
Dec 27, 2007 10:32 AM
