Can I use this grommet?
I have been searching for a pre made hole to run my amp power wire through on my 1994 Honda Accord and found a grommet in the middle of the passenger side floor. I wanted to know if this would be okay for the power wire to be running under the car thrn through the floor of the car.
https://imageshack.com/i/npn626j
Someone else mentioned a oem fog light grommet but I can' t seem to find the one mentioned.
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-can-i-wire-my-amp-3196432/
I know about this one. Problem is, I have only 17ft of wire. I ran 17 ft of string like I would if it were the power wire through that grommet to the trunk, and did not have enough to make it into the trunk. I have been searching for that fog light hole in my car itself and online. Still no luck.
I actually have found a grommet on the firewall to the top left of the ECU on the passengers side of the cabin. I am told that it is the OEM Fog Light Grommet. I am going to drill a hole inside of that grommet and place a watertight grommet liek the one you had posted to make sure no water flies into my cabin, especially sine I live in Western washington with all this dang rain, hahah.
Here is a picture of the Grommet inside of my car:
https://imageshack.com/i/jtpu3zj
If you pull back the top of the passenger side carpet, there will be a velcro piece (Should be) that the carpet attaches to. and behind it is like this black material (Believe it is insulation), there should be a circle shaped "plug." Once you pull that black piece out, the grommet will become visible.
sabideefoo
12
Oct 12, 2010 05:51 PM
spock_rocker
Mar 18, 2003 03:00 PM
