Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
dw-1 vs z-1
Old Feb 28, 2014 | 06:58 PM
uwharrier's Avatar
Default dw-1 vs z-1
I have a 2011 civic that according to the O.M recommends the dw-1 a/t fluid.Can anyone give me info on the difference between the dw-1 and z-1 or the benefits of one over the other.This is my third Honda car and first a/t Honda.Kinda wish I had picked the '11 civic 5sp but what the hell.Tranny seems to shift positive but smooth and down shift like a 5sp.(Almost like going through the gears).Also,does anyone know when to change the fluid?O.M only tells how to check and add. Thanks
Old Feb 28, 2014 | 09:15 PM
av911's Avatar
Default Re: dw-1 vs z-1
Z1 is old formula, DW-1 is new.
Old Mar 16, 2014 | 11:41 AM
Zebra's Avatar
DW-1 is compatible with the old formulation Z-1, which was phased out. Recommendations vary according to vehicle use from 30K to 15K for the 3 quart change. I change it out every 10K, as there are over 10 quarts in the transmission, so 3 qt. is only a partial change anyway. I figure transmission fluid is cheaper than mechanical repair, so why skrimp on the cost of 3 qts? It is easy for the DIY type - just drain and replace. Use 90471-PX4-000 crush washer for the transmission drain bolt.
cometflyer
Honda Civic (2001 - 2005)
Nov 25, 2015 08:32 PM
aha409
10
Oct 31, 2012 10:33 AM
kroze
10
Oct 8, 2007 02:14 PM
pr0gress
17
Apr 5, 2005 05:12 PM
audiphile
Jul 8, 2004 08:16 PM
