SOHC Civic manifold with GSR throttlebody
Old Oct 29, 2002 | 09:17 AM
cyberx's Avatar
Default SOHC Civic manifold with GSR throttlebody
i was wondering if i can get a 96-00 Civic EX manifold to bolt up to a GSR throttle-body and then port match them...... ??? i have heard this can work...... but i want to confirm it!!! please help
Old Oct 29, 2002 | 09:27 AM
kevcp's Avatar
Default Re: SOHC Civic manifold with GSR throttlebody (cyberx)
Yes it will work I'm waiting on my throttle body (in the mail) so I can do mine...
Old Oct 29, 2002 | 10:01 AM
93 EH3's Avatar
Default Re: SOHC Civic manifold with GSR throttlebody (kevcp)
kevcp, is that your 1/8th mile e.t with all that stuff you have listed in your sig.?
Old Oct 29, 2002 | 10:10 AM
Plan B's Avatar
Default Re: SOHC Civic manifold with GSR throttlebody (93 EH3)
If it is, dayum. I think he needs a clutch.
My 94 ex gude head/exedy clutch/weld up muffler ran 10.2
Damn gina, turn the A/C off.
Old Oct 29, 2002 | 11:07 AM
93 EH3's Avatar
Default Re: SOHC Civic manifold with GSR throttlebody (Plan B)
I ran 9.95 @67 mph. 93 si- cai, exhaust, lightened oem fly( 13lbs), exedy clutch, testpipe, stock everything else.
Old Oct 29, 2002 | 02:08 PM
kevcp's Avatar
Yeah first time at the track stock clutch shitty tires and no experience it will improve with time and practice if you think 10.6 was bad my first run was 11 something...
Old Oct 30, 2002 | 04:11 AM
cyberx's Avatar
what else would i need to do this GSR throttlebody to a civic manifold to work, does the bolts bolt right up with the manifold??? and how much should it cost me to port the manifold to port-match with the t-body..... also what intake will you be using for this setup???
Old Oct 30, 2002 | 04:27 AM
Plan B's Avatar
Machine work is not a universal service, hence it will not be the same price to get that done for me, as it would be to get it done for you.
I suggest taking the intake manifold and the throttle body to a machine shop and getting on the level with them, see how much they think it will cost.
If you don't think you can handle that, maybe this mod is out of your reach right now.
Hmm, i didn't think that the SOHC tb's and DOHC tbs had the same bolt pattern/coolant passages, but maybe they do.
I wouldn't bet on it though. If they are the same for the most part, you shouldn't need any additional hardware to hook this up.
Old Oct 30, 2002 | 05:29 AM
kevcp's Avatar
Yes almost all honda throttle bodies match up....
for more D-series info read this
https://honda-tech.com/zerothread?id=261161
Old Oct 30, 2002 | 05:32 AM
BERT-O's Avatar
quick upgrade
b20acura
11
Jul 25, 2011 12:44 PM
wrx'n you
May 19, 2009 09:09 PM
PacsterEg6
May 1, 2009 04:17 PM
ieatrice
10
Apr 9, 2007 03:29 AM
juicedricer
Nov 1, 2002 06:15 PM
