Which Clutch Should I buy?
Old Feb 28, 2014 | 01:07 PM
NinjaJDMB18c's Avatar
Default Which Clutch Should I buy?
Well it turns out my clutch is starting to slip at 3500 rpms in first n second gear. It's a stock type r so I need some opinions. Motor is a 98vb18c spec type r. Exedy stage 1 or 2 racing clutch a good choice n which one? The most I'm gonna do is skunk 2 tuner cams and gears and spring valves retainers. Skunk IM n TB 68mm. Thoughts? I'm open to other brands too. N should I get a light race flywheel too? Ebay has a exedy stage 1 with light flywheel for 400 shipped. That a good deal?
Sent from my Samsung Galaxy Note 3 using Tapatalk
Old Feb 28, 2014 | 05:40 PM
$MIKE$'s Avatar
Default Re: Which Clutch Should I buy?
Either one will work fine if you gonna keep it mostly stock,
If you plan on dumping clutch burn outs racing drag then maybe stage 2
Old Mar 2, 2014 | 01:58 PM
3kvr41998's Avatar
act 6 puck
Old Mar 2, 2014 | 02:21 PM
Jabuelouf's Avatar
I always stick with Exedy clutch + Fidanza Flywheel.
Old Mar 2, 2014 | 02:25 PM
JuggerNaut-CTR's Avatar
I never have had any complaints with the exedy stage 2. It will give you room to grow in case you ever want to boost the motor. It supports 285 ft lbs.
Old Mar 3, 2014 | 10:33 AM
Jtmvtec's Avatar
Exedy stage 2 disk, fidanza flywheel like stated above, and An Exedy throw out bearing is what I'm running now and I'm really impressed compared to the cheap organic disk I had before. Only put down about 2 at the wheels but it grabs for me
Stay away from act imo
Old Mar 5, 2014 | 10:25 AM
When u say cheap organic discuss were you referring to an organic exedy racing clutch or an Oem clutch..
Old Mar 11, 2014 | 03:29 PM
Jtmvtec's Avatar
A cheap organic racing clutch. Doesn't have to be from exedy.
Old Mar 15, 2014 | 10:22 PM
yozo1981's Avatar
Any experience with comp clutch? Im looking at one with a oem pressure plate but stage 2 clutch disk. I realize the pedal feel will be closer to oem but is there negatives to running oem pressure plate with a diff stage clutch?
Old Mar 16, 2014 | 02:54 PM
Teens10's Avatar
I'd go with Exedy stage 1, got one for my F22b1 and has been great for me.
Old Mar 27, 2014 | 11:53 AM
Neocaspian's Avatar
I'd recommend the exedy stage 1 because you dont want a stage 2 for daily driving a NA motor, its not necessary and a stage 1 will feel better.
Old Mar 27, 2014 | 07:29 PM
b20vteg757's Avatar
I just installed a competition clutch ultra light flywheel and stage 2 kevlar clutch kit and love it. Easy to drive but grabs very nicely. By the way I have a b20 vtec all motor n/a in mine with lsd gsr trans.
I would definately get a lightweight flywheel for n/a though. Less weight on the crank more power to the wheels. Now with a turbo and higher boost you can use a heavier flywheel so that you can hold boost longer between shifts. The weight of the flywheel helps keep the crank spinning when let off throttle. Anyways competition clutch is very trusted brand cant go wrong.
Old Mar 30, 2014 | 12:00 AM
Hatch It's Avatar
Exedy all day. With the route you're going I'd just go with Stage 1, and that eBay deal with the lightweight flywheel sounds good, just make sure the flywheel isn't crap.
Old Apr 28, 2014 | 11:41 PM
So I got the exedy stage 2 racing clutch and exedy light flywheel. Am I going to regret getting this stage 2 for a daily driver? Should i be returning it for a stage 1? I may go turbo next year with my tax returns...I'm expecting 220 at wheels with skunk2 stage 2 tuner cams and cam gears and spring valve train retainers and the basics (70mm intake manifold skunk2 and 68mm skunk2 tb) on my 98 JDM ITR hopefully . Errr I say hopefully, loosely too. Thoughts?
Old Apr 29, 2014 | 05:42 PM
mage00321's Avatar
If you plan on boosting later, roll with it! If it's too aggressive, that will be motivation to boost it sooner lol
Old Apr 29, 2014 | 06:17 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
For your goals a Stage 1 Exedy would have been plenty. The Stage 2 isn't horrible on engagement. Don't let the 3 puck scare you. Which clutch did you get - thin or thick disc Stage 2 Exedy?
Old May 1, 2014 | 12:10 AM
Thick stage 2. I saw the thins for track only. I haven't put the clutch in and can still exchange it. Should I return it for a stage 1 then? I'm concerned the pressure will be too much on my foot for daily driving
Old May 1, 2014 | 08:28 AM
DO IT ON ALL FOURS
IDK what to tell you. Everyone's opinion of what something feels like is their own. Anyone who tells you different is a fool. I have owned them all up to my current Exedy Twin Disc (aside from thin disc Stage 2) and the Stage 1 with the HD pressure plate is a little more over stock. The Stage 2 was a little more than than the Stage 1. How much exactly? IDK enough to notice but not enough to care - for reference I am 6'6" and close to 300 lbs muahaha.
If you are going to add on later for a lot more horsepower then keep what you have. If you are going to stay with what you got for some time then go Stage 1. If you are worried about clutch leg fatigue in city stop light/stop sign traffic or traffic jams then go Stage 1 as it will work for your setup.
Old May 2, 2014 | 09:09 AM
So was there a big difference in foot pressure between the stage 1 n stage 2 exedy thick clutch?
FlewByU352
Feb 5, 2011 07:44 AM
OBDII Integra
Sep 30, 2009 04:04 PM
DonReggeaton
18
Jun 10, 2009 03:11 PM
Duck Sauce
May 18, 2008 10:43 AM
