95 civic - horn wiring after installing nrg quick release steering wheel
95 civic dx sedan Im installing a nrg quick relase tomorrow
my horn isnt connected.
Thought itd be a good time to re install my horn.
what kind of wires do I need and is there and wire diagram that can help me?
Thank you.
what about wires to make the actual horn work thats what I really need.
Can I just go buy a new set or wires and hook it up? Or it needs to just those exzact wires that I cant find?
so i can wire in a completely new horn with new wires and everything??
i think that would be easier right?
just need horn
16g wires and come connectors?
cause i can't find the old wire horns in my engine bay at all
just need horn
that will be an issue you NEED those old wires from the bay...split open the dash/engine harness and find them. wiring up a horn from scratch won't be fun.
where would be a good place to start?
the old owner disconnected the horn and idk where the wires run,
95 dx sedan what color wire should i be looking for in the bay and under the dash?
once i find those i can follow other diy nag horn install.
thanks for you help.
This is a vid I made for someone else regarding a rywire harness install, it's on a OBD1 DC2 integra but the same applies to civic's. the 2 horn 2 horn wires are a blue/red stripe/silver spots and the other white/green stripe.
OneFreeMan
Honda Civic (2001 - 2005)
May 25, 2016 08:20 AM
IOSUA
Oct 6, 2007 05:44 PM
