rear wiper delete or not?
Old Feb 27, 2014 | 05:39 PM
duf2570's Avatar
Default rear wiper delete or not?
what do you thonk guy's about delete the rear wiper? i mean remove all the hardware(keep it fore sure) and install a bolt on delete kit?? my R isnt full oem but a advise is always good to know
Old Feb 27, 2014 | 05:40 PM
Demon R's Avatar
Default Re: rear wiper delete or not?
Do it. I have it on my car
Old Feb 27, 2014 | 05:49 PM
Ultraspeed DC2's Avatar
Sorry to hijack this thread but I had intentions of removing my wiper to replace the faded black plastic ring underneath it.
However, I want to say I've read stories of the back window shattering during removal. Is this possible? After removing the nut, I couldn't remove the wiper and didn't want to try additional force.
Old Feb 27, 2014 | 05:51 PM
duf2570's Avatar
just scared to be to much ''off oem'',,
Old Feb 27, 2014 | 05:57 PM
duf2570's Avatar
you can buy a bolt on delete kit if you feel unsafe
Old Feb 27, 2014 | 06:24 PM
duf2570's Avatar
i just buy a kit pswjdm
Old Feb 27, 2014 | 07:00 PM
PaulMc's Avatar
Painfully Stupid
What's the point?
Old Feb 27, 2014 | 09:27 PM
B16EJ's Avatar
if you do decide to remove the rear wiper there is a black plug on the firewall somewhere around the battery, i think under the tray or off to the side somewhere but its the exact size as the hole left in the glass after removing the wiper, and fits perfectly.
i just figured id let you know, you could try it out just to see if you like the look and then order a delete kit or just rock the black rubber plug... thats what i did because im cheap lol. im sure most guys with DCs dont realize they are rolling around with the solution to the open hole when they remove their wipers.
Old Feb 27, 2014 | 09:34 PM
white rocket's Avatar
I have that plug. Works like a charm . Plus it looks factory stock. There may be an old thread kicking around with the part number.
Old Feb 27, 2014 | 10:24 PM
90blkteg's Avatar
Password jdm version 2.0 rear wiper delete. I have it on mine it's a sweet little part & you don't have to worry about it coming off or being pushed in
Old Feb 28, 2014 | 02:13 AM
duf2570's Avatar
Originally Posted by PaulMc
What's the point?
a better looking rear end/less weight buy removing this part,,so for those who have a 100%(or close) oem pristine ''R'' i will certainly not do that
I just create the thread to have advise from R owner who've done it( pro and cons) in fact that i will keep all the rear wiper hardaware i will be abble to reinstall it .but the looking is a lot sharp whitout it
Old Feb 28, 2014 | 02:57 AM
duf2570's Avatar
I found it but feel better to install a real kit...oem isnt avalaible here
Old Feb 28, 2014 | 05:53 AM
98ITRAgain's Avatar
X2
Old Feb 28, 2014 | 06:25 AM
94rs-turbo's Avatar
I can make those delete plates, sits almost flush, been doing that for years. PLus doesn't have free advertisements and cheaper
Old Feb 28, 2014 | 06:42 AM
Todd00's Avatar
I said I don't want a title!
If I had to guess, I'd say the entire rear ITR wiper assembly weighs 2-3lbs or so. It isn't all that heavy. The one on my '91 Si was twice the weight as it had much less aluminum on the motor.
It was one of those "fads" 10 years ago, but anymore I don't think it looks any better or worse without it.
Old Feb 28, 2014 | 09:48 AM
PaulMc's Avatar
Painfully Stupid
I bought mine from the original owner with the wiper delete, there was no noticeable difference in performance without the 2-3lbs and I have to agree with Todd's statement quoted below that it really doesn't make it look any better/worse with or without it. Sometimes I even go to turn the wiper on when it's covered in rain water forgetting it's not there. I've owned several Integras in the past that had the rear wiper so I'm just used to it.
Just IMO and as a fellow R owner, keep the damn wiper on there! Nobody is going to think any better or worse of your R because of it.
Old Feb 28, 2014 | 10:05 AM
B16EJ's Avatar
some of the replies make me lol... "dont want to remove the wiper on a pristine r" anything done in the wiper removal process can be undone when putting it back together and as long as its done properly nothing will have to be broken and everything will be just as "pristine" as it was before taking the wiper off...
i took my wiper off because i think its hideous. the car gets driven 3 months of the year if that, and certainly not in the rain so its a non issue for me. the wiper, motor and all related parts are tucked away in the garage in a honda bag incase i ever want to put it back its there.
Its ok to try something out, if u dont like it put it back and dont tell anybody it will be our lil secret, promise.
Old Feb 28, 2014 | 12:04 PM
Todd00's Avatar
The plastic on these cars isn't getting any younger and sooner or later they are going to stop making a lot of the interior pieces (if not already).
To risk taking the rear wiper out of a pristine 15 year old car and having tabs break, plastic crack, etc. just isn't worth the "look" or the effort.
Plus, it's an OEM piece. The rear wiper fits the era and doesn't look too bad on the car. To you it is hideous. To me, the only way it looks 100% is if you use the '97 R rear glass...otherwise you have a useless plug in the glass.
Old Feb 28, 2014 | 12:23 PM
duf2570's Avatar
,,,remove this isnt a way to improve the look like a good looking wheel set can do,,,but we can stated that this part is 99% useless and like b16ej said its a hideous part, for the weight loll 3-4 lbs no way to see improvement in 0-60mph time range,,,yes but(not my case) in removing spare tire/hardaware we can reach 20-30lbs,,,
and yes if my ''R'' was a 100% oem ultra pristine garage queen,,i will not remove it even if i can reinstall easily,,..
Old Feb 28, 2014 | 12:35 PM
Todd00's Avatar
It is not useless nor is it hideous, but to each their own.
Old Feb 28, 2014 | 12:40 PM
IanBlake's Avatar
no
Old Feb 28, 2014 | 01:48 PM
I totally did it for the "look" back in the day. With the OEM plug I feel it still retains it's OEM-ness(is that a real word? haha!) and doesn't look out of place at all. Not having the wiper doesn't effect me in any negative way as it is a summer only non-rain driven vehicle. As always, to each their own.
Old Feb 28, 2014 | 03:29 PM
BlueIntegraBoy's Avatar
I never used mine, and off it went.
Old Feb 28, 2014 | 04:09 PM
duf2570's Avatar
this is also why i will remove it
Old Feb 28, 2014 | 06:10 PM
TheShodan's Avatar
Moderator
I removed mine as well using a nice How-to by Team-Integra. It even had part numbers for the large grommet to replace it with. But, be careful you need a 23mm socket to get the assembly from the window. Keep plenty of towels around the glass, and don't use an adjustable C-wrench, as the lip of the bolt won't allow it to seat (that's how most glass "cracks" occur).
http://www.team-integra.net/forum/bl...er-delete.html
I wound up using the rear wiper washer jet as my intercooler sprayer. I was even able to keep the control on the signal arm on the driver steering column.
Enjoy.
