93 accord cant install a fuel kill switch properly
hi this is for my buddys car we been restoring etc. gotten to the point where its a nice car. after putting a fuel kill switch and others on mine using ff squad ecu pinout. i cannot seem to locate or identify the proper wiring for his. i believe top of head. if more info needed ill obtain. but i believe only engine for this year was a 2.2l sohc i already know to run from the fuel pump under back seat or the relay under dash driver side but really wanting to run directly from ecu. why not really sure just seems like un obvious to check if looking for wire path origin. but cant find a pinout for this car. its a 93 accord sohc manual transmission. every ecu pinout found is not the right one. cut in to wires that were not the right ones. so were wrong.
http://technet.ff-squad.com/wiring.obd1.htm
This pin out is the same for every obd1 honda with the exception of the 94'95 accords which have pins A6 and A10 swapped.
I've never ran a fuel kill switch but I suppose if you wanted to you could tap into the A7 pin at the ecu.
Your problem is you could be looking at the ecu connectors backwards. Don't focus on the colors, they will be different, just focus on which slots are empty and that should tell you which way to view the connectors or the ecu in relation to which pins that site show.
thts my only problem was i had used that ecu pinout in past and seems off for accords. if youre saying that colors dont matter then ya maybe i was in right ball park but using that trying to compare colors threw me way off. so youre saying this pinout will work for sure. even if wrong colors
just colors will be off. nice i really appreciate the info that what killed me couldnt see cutting into wires without them matching on color. lol but that good. i will give a shot thankyou for advice.
Linus Tuleborn
Apr 4, 2024 03:49 AM
Mugen Hamster
Audio / Security / Video
28
Mar 1, 2004 05:28 PM
