95 ls vtec turbo partout
Old Feb 26, 2014 | 01:17 PM
dcwoodard's Avatar
Default 95 ls vtec turbo partout
My car is too ugly to sell with all these good parts. So I am going to partout the drivetrain and single cam it to sell.
1993 b18a1 block with srp 9.5:1 pistons (stock sleeves 81mm) Eagle rods, arp studs, oem b16 head gasket, ge sandwich plate, -10an block fittings, b16a head (stock) with gsr cams, obd1 distributor, fx300 clutch, stock ls transmission (slight 3rd grind sometimes) oreilly lifetime axles and starter, and ls vtec kit. $1500 will come with stock b16 injectors and a stock exhaust manifold shift linkage and shifter also.
hasport 3 post mounts 62a $200 (eg dc)
blue ridge motorsports top mount t4 manifold with 38mm wastegate flange (non divided) $650
blue ridge motorsports catch can with valve cover and all 4 hoses already made for b series $275
comp ct4 6765 triple ball bearing turbocharger in perfect shape $850 (divided t4)
rc 750cc injectors with obd2 clips $200
Don't have pics with my user name currently so I can send pics if texted at
(615)870-9796
Text is the fastest way to reach me.
Old Feb 26, 2014 | 01:20 PM
dcwoodard's Avatar
Default Re: 95 ls vtec turbo partout
Omni 2.5 map also $40
ectuned ecu for turbo and manifold up to 20psi $200 has boost by gear installed
custom 2.5 intercooler piping $250 with 50mm tial flange
tial 50mm bov $150
tial 38mm wastegate with 17psi $175
engine has just over 3k miles on it. I only have had the turbo and tune for 600 miles. can come ride if interested
Old Feb 26, 2014 | 01:55 PM
Amiller1491's Avatar
Hey. I'm interested in the tial wastegate and bov. I texted you. In case you didn't get it, my # is 225-772-423five.
RicerNtheMaking
Nov 28, 2012 09:47 AM
silverdc2integra
Sep 28, 2009 11:17 AM
91lsteg
Mid-Atlantic (Sales)
Jul 21, 2009 10:35 PM
kshgl87
Oct 6, 2008 10:12 AM
Tex Blackwell
Jan 10, 2006 05:17 PM
