TDC Sensor Code 8 After Installing New Dizzy
Just replaced a blown distributor on my 93 del Sol with d15b, now code 8 TDC sensor is intermittently coming on and off. Dizzy is brand new and there was no MIL before replacing. I followed the instructions on Alldata for installing the new dizzy but the light is still coming on and off whenever it feels like it. Checked all connections I will ohm everything out but wanted to ask if there was a known problem before I did. Thanks
Well the CEL stopped coming on for a while so I left it alone. Now it's back and seems like it's here to stay. Still code 8, TDC sensor. Which wires are you referring to Ron? A pic would be most helpful as I'm quite unfamiliar with the inner workings of distributors and no longer have access to AllData.
Thanks
Thanks
Ok I will give it a go tomorrow and let you know how it turns out. I'll be back for help I'm sure. Just to confirm, when I took the old distributor off there was really only one way for the new one to go back on. If the stator was somehow rotated 90 degrees when I reinstalled, would I be experiencing the same problem?
sebTeggy
Oct 21, 2011 09:28 PM
Mr.Death
Oct 5, 2008 03:47 PM
turboxsi
Jun 10, 2003 03:32 PM
