Y8 manifold on y7 head
Old Feb 25, 2014 | 04:45 PM
freddy chavez's Avatar
Default Y8 manifold on y7 head
Ok guys i knw theres tons of info on this swap and ive done it b4 but for some reason im stumped right now.got a y8 intake manifold of a 00 civic auto and put the y7 trotthle body so i wouldnt have to mess with the wires just extend them and my car idles all the way to 4000...no leaks.tried a manual y8 manifold same with the y7 tb and plugged the rear iacv to use the one on the tb y7 amd still spikes up to 4000...wtf am i doing wrong?any help would be appreciated thanks
Old Feb 25, 2014 | 06:16 PM
Default Re: Y8 manifold on y7 head
Any1????
Old Feb 25, 2014 | 06:25 PM
canadaek's Avatar
Originally Posted by freddy chavez
Any1????
99-00 y8 have air injection holes if not plugged you get a large leak
Old Feb 25, 2014 | 06:42 PM
I changed it to a 5 speed y8 manifold and it idles at 2000 now but when i disconnect the tps and map its perfect,but once i turn it off and back on its back at 2000.
Old Feb 25, 2014 | 06:43 PM
d the y 8 manifold im using now dsnt have the air injection holes.
Old Feb 25, 2014 | 10:08 PM
tlarimer's Avatar
Tps and map plugs swapped?
Old Feb 26, 2014 | 12:09 AM
eghatch9295's Avatar
Stancetard Hate Monger
vac leak? spray carb cleaner around vac connections, check for a change in idle.
Old Feb 26, 2014 | 04:42 AM
Axatax's Avatar
You have a vac. leak or your TPS/MAP sensor plugs are reversed.
Old Feb 26, 2014 | 05:39 AM
HondaPartsHero's Avatar
Technical Hero
Which intake manifold gasket are you using?
Old Feb 26, 2014 | 08:12 AM
The y7 gasket.seems to be no leaks.the car runs and idles good if I disconnect the map and tps sencor.
Old Feb 26, 2014 | 08:18 AM
tlarimer's Avatar
You should be using the gasket for the Intake manifold you are using.
Start there, You could have also mixed up the TPS and MAP plugs and plugged them into the wrong sensors.
Old Feb 26, 2014 | 11:14 AM
y7/y8 use the same felpro gasket.
Old Feb 26, 2014 | 11:29 AM
tlarimer's Avatar
OP hasn't specified what year IM he's using, 99-00 auto and manual both have AIR holes and use different IM gasket than 96-98 Y8/96-00 Y7.
Old Feb 26, 2014 | 11:44 AM
Technical Hero
yep that's what I was getting at
99-00 D16Y8
17105-P2P-A01
96-00 D16Y7/Y8
17105-P2F-A02
96-98 D16Y5
17105-P2F-A02
99-00 D16Y5
17105-P2J-014
Old Feb 26, 2014 | 02:23 PM
I have a. 99 auto y8 manifold. I got it all done 2day guys. Thanks for all the imput.i re started all over and tore it dwn and tried it again and came out good this time.only thing that i did do was plug that bottom hole inside the tb wich from wat ive heard some people dnt have to do that.still confused but my car is running right now
Old Feb 26, 2014 | 02:32 PM
ej1b18c1's Avatar
http://www.d-series.org/forums/diy-f...manifolds.html
Old Feb 26, 2014 | 05:01 PM
Ok I tought I had it but guess not.i checked and I have no vac leaks at all.all the injector plugs are plugged.but now it surges from 2000 to 1000.wat can it be?been at it since Monday and it's driving me crazy now.
Old Feb 26, 2014 | 05:49 PM
I meant air holes are all plugged
Old Feb 26, 2014 | 10:19 PM
ej1b18c1's Avatar
Iacv clean?
Old Feb 27, 2014 | 01:35 PM
Now i got it.thanks guys turns out the tb gasket autozone game me was not like the oem one.put the original one on and fixxed all my problems.
tobe1424
Jan 19, 2006 09:14 AM
JDMKid71
10
Dec 12, 2005 07:14 PM
scttydb411
Jan 31, 2004 08:59 PM
TheAutoboxer
Jun 8, 2003 07:10 PM
fastcrxsi90
Jan 20, 2003 02:20 PM
