Brake Service
Old Oct 29, 2002 | 08:09 AM
YipMan_Style's Avatar
Default Brake Service
Please explain it to me like a 5 year old on what exactly will they do for $350+ dollars.
I want to know so I sound some what smart when I talk to them, so they won't rip me off.
Late,
Old Oct 29, 2002 | 08:22 AM
Spade's Avatar
Default Re: Brake Service (YipMan_Style)
Late,
You have to ask them. Some may just change the pads and charge you that much.
Old Oct 29, 2002 | 08:25 AM
martini's Avatar
they probably turn the rotors (or at least inspect them for warpage). inspect the brake pads (maybe replace). Ans probably flush the brake fluid.
Old Oct 29, 2002 | 08:35 AM
Are rotors = disc?
What wears out, disc pads or roters?
If the rotors are warp, do they need to replace it or grind it smooth?
When I step on the brake, there is sort of a "pumping" feeling like the disc is not smooth or something. Is that correct?
Late,
Old Oct 29, 2002 | 08:37 AM
Spade's Avatar
Are rotors = disc?
Late,
The pumping feeling is the warped rotors.
You need new ones. Buying good pads and new rotors cost me 150 dollars and one hour of my time. (took my time and cleaned stuff too)
Old Oct 29, 2002 | 08:55 AM
ExAcc's Avatar
Are rotors = disc?
Late,
Rotors are the discs....
If the rotors are warpped, depending on the extent, it could be resurfaced (grind). But, it is recommended that you replace the rotor, because grinding it will only be a temporary fix to the problem, and it will warp again soon. Also, I was told that the labor to resurface it and the cost of new rotors approx $60 ea. would be about thesame.
The pumping feeling or pulsating feeling that you get from the pedal is your rotors being warpped. I had thesame problem with my car. It cost me $381.00 to replace both front rotors and brake pads, and the rear brake pads plus labor. I don't know how to do it myself, so I had to go to a shop....
Brakes work great now....
turnsignalandy
Nov 12, 2006 03:35 AM
old_school_dohcvtec
Apr 30, 2005 07:47 AM
faSHOwidIT
Apr 18, 2005 02:06 AM
davken1102
Mar 28, 2004 08:28 AM
ophdehEEzY
Mar 8, 2003 07:06 PM
