ZC SOHC info needed
Old Oct 29, 2002 | 08:08 AM
crxracer's Avatar
Default ZC SOHC info needed
Any of you folks know the differences between the ADM 1.6 D16A6 SOHC (88-91 CRX Si) engine and the JDM 1.6 ZC SOHC engine? Any info would be appreciated. I am replacing my original engine with one of these and I would like to know the differences, thanks.
Old Oct 29, 2002 | 08:42 AM
ExospeedAMcrx's Avatar
Default Re: ZC SOHC info needed (crxracer)
same thing. nothing diff. if there was, its a slightly better cam on the JDM sohc zc, but nothing spectacular.
Old Oct 29, 2002 | 09:20 AM
BLAP BLAP!!!
Guest
Posts: n/a
Default Re: ZC SOHC info needed (exospeedAMcrx)
The zc single cam makes about 5-8 more horse power.
Old Oct 29, 2002 | 09:43 AM
BeEfiEBuNz's Avatar
bah i'm very confused.. people told me many times sohc zc is 128 hp.. some said 110 some said 112 some said 118 -_- im confused. whats the exact hp/torque of the jdm sohc zc engine?? anybody know? and isnt it more similiar to the engines outta the 92-95 civic si's? but none vtec.. ? i kno those are like 125 hp vtec.. so i would think so.. anybody answer this plz?
Old Oct 29, 2002 | 09:46 AM
altoid's Avatar
Default Re: ZC SOHC info needed (BeEfiEBuNz)
dohc zc is pushing 130, sohc is arouund 110-112...nothing major
Old Oct 29, 2002 | 09:47 AM
subgeniusdude's Avatar
It's rated in PS,but comes out to 129 HP.
Glenn
91 EF hatch
Old Oct 29, 2002 | 09:56 AM
BeEfiEBuNz's Avatar
Default Re: ZC SOHC info needed (subgeniusdude)
128;p
Old Oct 29, 2002 | 10:13 AM
PSIKOTICcrx's Avatar
My bro has a sohc zc in his crx. its 120hp. http://asia.vtec.net/topics/zc.html
Old Oct 29, 2002 | 10:50 AM
crxracer's Avatar
It looks like we all have conflicting opinions on this engine. It seems that it might have SLIGHTLY more HP than the ADM engine. Probably around 4-6hp IMO. Does anyone have hard facts on the blue printing of this engine? ie: cam, valve, intake specs? Compression specs, etc?
Old Oct 29, 2002 | 12:37 PM
chief_rucka's Avatar
I to have a ZC SOHC in my CRX!!! anyone else has one from SO. CALI? i would like to meet you guys and learn more. cause i to am confused on the specs. pic os my engine:
Old Oct 29, 2002 | 01:15 PM
Melt's Avatar
Default Re:
I also have this engine and also have no idea what it puts out. Cant possibly be putting out 129 cause I still have DPFI, so 118 is the number I believe.
Here is the only pic of the engine I can find for the moment, I have more but imagestation is being gay
Old Oct 29, 2002 | 04:20 PM
the sohc zc pulls pretty good.. my bros was turbo before, untill he got caught, and took it out. i have pictures of it turboed but dont know how to post it up.
Old Oct 29, 2002 | 04:40 PM
JDM CRX's Avatar
Default Re: ZC SOHC info needed (PSIKOTICcrx)
SoHC ZC is 128 HP,,,, the DOHC ZC is 135
the SOHC wieghs 20 LBS lessthan the DOHC and revs up quicker due to the less valvetrain. ive had a SOHC ZC in my one CRX's,,, always beat a DOHC ZC and pulled mad great!! heres a SEcret!! get a carbed SOHC ZC and pull all the carburator **** off and replace with your PGMFI . the Carburated ZC has a more aggressive cam than the Fuel injected one,, so when you put the fuel injection mani on the Ex-carburated engine, it makes some nice bottom end power, and more power than the stock carbed or stock fuel injecte.. works best with intake., header and exhuast of course
Old Oct 29, 2002 | 05:03 PM
Default Re: ZC SOHC info needed (JDM CRX)
the sohc zc is 120hp.. the sohc zc vtec is 130
Old Oct 29, 2002 | 05:35 PM
altoid's Avatar
gah the sohc zc isn't close to 120 hp...but whatever...
Old Oct 29, 2002 | 05:49 PM
Default Re: ZC SOHC info needed (altoid)
http://asia.vtec.net/topics/zc.html ...altoid?
[Modified by PSIKOTICcrx, 2:53 AM 10/30/2002]
Old Oct 29, 2002 | 06:17 PM
kim_2_da_chee's Avatar
i have it.
120hp
also, to those of u who have it too.... what is the point of the "dual-point fuel injection?" i tried to clean my throttle body today, and i had to take off this black cover, and then there were TWO throttle inlets! jesus christ that was a bitch.... it was one on top of another one...
[Modified by kim_2_da_chee, 7:21 PM 10/29/2002]
Old Oct 29, 2002 | 07:12 PM
altoid's Avatar
thats for the dohc, i've talked to honda master technicians who do this stuff. I'll ask again, but im pretty sure the sohc is closer to 110 than 120
Old Oct 30, 2002 | 03:23 AM
crxracer's Avatar
I'll have to agree with altoid. I believe the ZC SOHC is around 112hp. It is rated at 120ps which ia around 112hp. But I am wondering what is actually different? must be in the head, maybe cam & valves.
Old Oct 30, 2002 | 05:18 AM
Superhatch's Avatar
It could just be in the porting. I know that the B18b makes more power over the B18a mainly because of the porting on the intake side. *shrug* I doubt well ever know. I have a sohc zc in my car now...and I dont think it pulls 12hp stronger than any of the d16's I've had.
-Jake
Old Oct 30, 2002 | 05:26 PM
Leets's Avatar
Default Re: ZC SOHC info needed (SuperHatch)
I'll have to agree with the 112 claim. I have the the sohc zc and it doesn't pull any harder than the d16a6 with ported/polished head I used to have. I haven't dynoed it, but I seriously doubt it's puttin out 128.
Old Oct 30, 2002 | 05:45 PM
Default Re: ZC SOHC info needed (Leets)
ps is the same thing as horse power... as you can see on the page posted here http://asia.vtec.net/spfeature/hondaxref/index.html the b16b is rated at 185ps... the b16b is 185hp... the the h22 spec s is rated at 220ps.. the h22 S is 220hp.. my brother has a sohc zc in his crx, it sure pulls harder than the stock si motor.
Old Oct 30, 2002 | 05:49 PM
the sohc zc has a more aggressive cam and slightly higher compression over the d16a6.
Old Oct 30, 2002 | 05:58 PM
ThatRicerDaniel's Avatar
zc is a waste. get a b swap or just buy a single fogger.
Old Oct 30, 2002 | 08:26 PM
MrTodd's Avatar
Default Re: ZC SOHC info needed (NitrousDreamz)
Honestly, I don't think the SOHC ZC's compression is any higher than the USDM D16A6... I believe it's just the cam, and maybe in japan it was coupled with a slightly more aggressive ECU? Prolly not, I think it's just a slightly more agressive cam.
