*Write-Up* Nardi Classic single contact horn into NRG 2.5 quick release
Due to a lack of info when I was doing research, I decided to make a quick write-up on installing my Nardi Classic horn button with a single contact onto the NRG 2.5 quick release.
This method doesn't utilize spacers or retaining rings. It's quite simple.
A single contact horn will work as long as it contacts the metal part of the quick release (self grounding). However, the black NRG QR seems to be powder coated, and I didn't want to ruin the finish to get a good ground connection.
I utilize the supplied ground wire in this write-up.
While doing research, I saw the horn buttons installed a number of ways, mostly jerry-rigged and sloppy; so I hope this helps someone in the future.
Step 1.
Drill a small hole in the tab of a female spade connector.
Step 2.
Remove the retaining spring that holds the horn components together.
Step 3.
Step 4.
Reassemble the horn button.
Step 5.
Connect wires to horn (+) and (-).
Step 6.
Install
Done!
I suggest testing the horn before bolting everything together!
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
Step 6.
Install
Done!
Chance EG
Jul 25, 2017 06:22 PM
lazyxazianxboi
Jan 4, 2010 09:10 AM
