Suspension & Brakes Theory, alignment, spring rates....
megan springs spring rate
Old Feb 24, 2014 | 07:24 PM
vega5415's Avatar
Default megan springs spring rate
I am looking into purchasing Megan lowering spring for my ek hatch. On there description they say the rear spring rate is at 230. This is a pretty high spring rate for a hatch. if I install it will it sit higher than the front because of the lesser weight that there is in the rear of the hatch?
Old Feb 25, 2014 | 03:21 PM
vega5415's Avatar
Default Re: megan springs spring rate
Bump
Old Feb 25, 2014 | 05:34 PM
redlinetuning's Avatar
That spring rate is nothing. Some people use 450 or more. The height of the car at which it sits has nothing to do with spring rates. The spring length and spring perch height will though.
Old Feb 25, 2014 | 06:41 PM
vega5415's Avatar
Thanks
Old Feb 26, 2014 | 12:01 AM
Kozy.'s Avatar
a.k.a. Komodo
Also with cheap springs like that, a more correct statement would be 'around 230lbs'. They might vary 10lbs from one spring to another.
Old Feb 26, 2014 | 07:38 AM
98civdx's Avatar
Master Detailer
That spring rate is nothing. I daily a over double that.
patrickstar
Suspension & Brakes
Feb 17, 2009 11:49 PM
Jhonny Ricer
Suspension & Brakes
Mar 29, 2007 03:30 AM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Superhatch
10
Feb 8, 2002 06:59 PM
MrBite
Dec 9, 2001 09:09 AM
