97 Civic vacuum leak problem after removal of cruise control
Old Feb 24, 2014 | 06:46 PM
VTECkid97's Avatar
Default 97 Civic vacuum leak problem after removal of cruise control
i have a 97 honda civic with the y8 motor. when i had the engine out rebuilding i removed the cruise control. well i noticed the other day the vacuum line that went from the cruise control to the back side of the intake manifold is open. but when i plug it with my finger the engine wants to die. should i plug the hole then re-time the engine. since when it was put back together it got timed with a vacuum leak? any help would be great.
Old Feb 24, 2014 | 07:26 PM
Former User's Avatar
Default Re: vacuum leak problem
Plug the nipple, and then reset the ECU. You can only adjust the ignition timing when the engine idles to spec.
Old Mar 3, 2014 | 02:06 PM
VTECkid97's Avatar
Default Re: 97 Civic vacuum leak problem after removal of cruise control
thanks ill give it a try. to reset the ecm i can just pull the fuse and wait ten minutes or is it better to disconnect the battery for a while?
Old Mar 3, 2014 | 02:09 PM
^this, but 3 minutes should be fine.
attz0r
Feb 18, 2014 03:29 PM
progekSiR
May 5, 2012 08:13 AM
turbodelsolb16a2
10
Dec 28, 2008 01:41 PM
1wiperDude
Nov 14, 2008 09:21 AM
cqdiep
Sep 6, 2007 04:30 AM
