b17a1 compression
Old Feb 24, 2014 | 12:54 PM
rmrider12522's Avatar
Default b17a1 compression
So I ran a test On my b17a1 and got 150 across the board. Should I be worried? Seems a tad low to me. Thanks in advance
Old Feb 24, 2014 | 01:10 PM
kyden's Avatar
Default Re: b17a1 compression
as long as it's consistent i wouldn't worry too much. was the throttle all the way open?
Old Feb 24, 2014 | 01:12 PM
No didnt touch the throttle, does that make a difference? And also I believe that the valve seals are getting worn because it smokes a little after vtec
Old Feb 24, 2014 | 04:53 PM
doood's Avatar
been there done that
Do it again with the engine at operating temp with the throttle all the way open
Old Feb 25, 2014 | 06:02 AM
Alright sounds good, ill see what happens, should I just be worried about inconsistent numbers? Thank you
Old Feb 25, 2014 | 06:13 AM
kyden's Avatar
the engine can't make any compression if it can't get air in. that's why the throttle has to be wide open.
Old Mar 1, 2014 | 08:16 AM
Finally got around to re doing the test and got 205psi in all cylinders, much better than 150! Thanks everyone!
1992cxhatchB16A2
Oct 21, 2008 06:42 PM
anth2k4
Mar 25, 2008 06:20 PM
drumminforev
13
Sep 19, 2006 05:42 PM
98prelude98
Apr 12, 2005 08:39 AM
jaredfmn
May 30, 2002 11:33 AM
