Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch barely passing
Old Feb 24, 2014 | 12:15 PM
raverx3m's Avatar
Default clutch barely passing
act stage 3 clutch kit wirh about 20% life left
Bled the clutch yesterday because it wasnt even going in gear.
Now it barely goes in gear
I have to press all the way to get it in gear
Pedal feels soft for about 60-70% of travel then i feel pressure like it is with srage 3 clutch
And it barely goes in gear at that point.
Is it slave or master cylinder problem?
I dont want to throw money away for part swapping.
Pressure plate looked good when i took it apart
Old Feb 25, 2014 | 08:16 AM
94CivicSi's Avatar
Default Re: clutch barely passing
Broken clutch release arm? I broke one with a Clutchmasters stage 1 on a D series and had similar symptoms. They crack right a the pivot ball.
I also had a problem bleeding the clutch on my last tranny swap. For whatever reason, gravity bleed was the only way to bring it back and it's been fine ever since.
Old Feb 25, 2014 | 08:17 PM
slowcivic2k's Avatar
As the disc wears, the clutch point will move towards the floor. (this is caused by the fingers moving outward as the disc wears.)
If a hydraulic problem exists, if you hold it to the floor, the car will slowly creep if you are in gear. If not, your clutch is too worn, or your flywheel surface/fork is not in the correct position in relation to the arm. This can also mean the arm itself is bent.
Old Feb 25, 2014 | 08:38 PM
raverx3m's Avatar
yea the disc is worn which is strange its worn more on the side facing the pressure plate
and the pedal feels noo pressure at all until about 60-70% travel then it gets really stiff and i have to press all the way to the floor to shift
my friend told me the new stage 3 clutches are not as stiff. mine is from 2006
actually its the AI4-XTSS clutch kit
Dc295kid
Dec 19, 2009 07:05 AM
96 EX
11
May 15, 2009 10:29 AM
champLSinteg
Apr 8, 2009 02:32 PM
JDM_SOHC
11
May 9, 2007 10:52 AM
