wheel size
Old Feb 24, 2014 | 11:41 AM
MANualBoy's Avatar
Default wheel size
I own a 93 civic sedan, I'm going to be buying new wheels soon. I'm considering 14x7 with a -13 offset with a 195/45/14 tire. Do you know if I will have any rubbing issues?
Last edited by toyomatt84; Feb 24, 2014 at 03:25 PM. Reason: Removed opinion request as it is a forum rule violation.
Old Feb 24, 2014 | 03:25 PM
toyomatt84's Avatar
Sanji
Default Re: wheel size
That's going to require a lot of negative camber to fit properly. Also, those tires are dangerously undersized for the car.
Old Feb 24, 2014 | 07:03 PM
MANualBoy's Avatar
Thanks for the reply, I appreciate it. so maybe a 14x6 -13? What tire would you recommend, as you could tell I went wayy overboard with the tires.
Old Feb 24, 2014 | 07:41 PM
toyomatt84's Avatar
Sanji
What's the obsession with -13 for an offset?
A more fitting tire for a 14" wheel would be 195/55/14 (if you can find tires in that size), or more commonly 195/60/14.
Old Feb 25, 2014 | 09:17 AM
MANualBoy's Avatar
Just thought -13 might look good. Thank you for the info I appreciate it
Old Feb 25, 2014 | 05:21 PM
toyomatt84's Avatar
Sanji
-13 will look different, depending on what the width of the wheel is. So, judging a wheel by only the offset is almost entirely useless.
-13 on a 6" wide wheel will have an inch less of lip surface, when compared to that of a wheel that is 8" wide and has an offset of -13.
Old Feb 25, 2014 | 06:40 PM
MANualBoy's Avatar
Ya I feel you, what would be your recommendation for tires and wheels then? I'm rather new to this if it wasn't already blatantly obvious. I'm looking at the work equip 03 i do lile the negative offsest look and I want them to look prett flush to the fenders on my civic, I also have plans to lower it soon. Thanks advance for all your help and insight, it's really good to know we still have people who are actually interested in helping others here on HT !
Old Feb 25, 2014 | 06:45 PM
toyomatt84's Avatar
Sanji
If you're looking for that perfect fitment setup, I'd say look towards a 15x8 +20 or so. It can be fit with a little bit of negative camber, rolled quarter panels/fenders, and still manage a safe tire setup.
Old Feb 25, 2014 | 10:30 PM
MANualBoy's Avatar
Thank you so much! You have saved me a great deal of time, a tip of the hat to you good sir.
MurtazaDSM
Apr 3, 2011 09:43 AM
nomoshing
Mar 18, 2010 04:37 PM
alacard
Oct 17, 2009 06:19 AM
civics4lyfe
47
Jan 29, 2009 08:52 AM
ej0513
Jan 18, 2009 07:10 AM
