OBD1 motor in OBD2b Car - wiring and distributor questions
I have searched and searched, I cant find anything concerning my particular swap, i have found bit and peices or information everywhere which have been helping but i want to end this confusion and just get a solid answer.
I have a EK obd2b civic EX, I recently blew the D16y8
I swapped in a B16a SIR obd1 motor I had laying around.
Everything is together and bolted in ready to go; however, im having problems plugging it all in.
This will be ran on a obd1 p30 ecu with the obd1-obd2b jumper harness.
Quesitons:
What are my options to get the Dizzy to work?
The IAT has already been relocated and plugged up.
what other wiring issues do i need to adress?
Quesitons:
for the dizzy u can buy a conversion harness other then that u should be set...emissions time this will not pass though.. u will have to use a obd2 computer and crank sensor
I live in Louisiana no emission here.
Iv looked and looked but keep getting confused as to what jumper harness i need for the dizzy. PWJDM sells one and descibes exactly what i need, however at the bottom says it does not work with a 99-00
Something about the obd2B makes it more difficult than a obd2a
obd2b has 2 plugs and obd2a only has one... u should be able to find one for your year just make sure it is the correct one
OBD2B and OBD2A both have one plug, the OBD2B uses a smaller one plug. OBD1 uses two plugs. You'll need OBD2B to OBD1 like this
http://www.rywire.com/catalog/obd2-8...pter-p-45.html
Also you'll need an alternator adapter.
Reuse your Ex injectors
I just purchased that adapter an im going to give it a try
Yep already have one. The whole swap is done ready to start minus this damn dizzy!!
I have a dohc obd2 dizzy, it works with motor but uses the big plug and and will not work with my harness. THe obd1 dizzy i have wont plug either. Iv tried both routes.
Im really hoping that harness i ordered works flawlessly and this thing just starts right up.
you have an obd2b d series plug, which is the rectangle 8 pin. B series still used the square plug.
http://www.rywire.com/catalog/obd2-8...pter-p-43.html
that is the one to use if you're going to use the obd2 b series distributor.
Should i run the obd1 or 2 dizzy?
I beleive i also have to run a wire for my tach to work?
adnoHCivic
Jul 24, 2005 03:03 AM
