ac is always on even if its on heat
Old Feb 23, 2014 | 06:50 PM
Kursatben's Avatar
Icon2 ac is always on even if its on heat
i have a 1991 civic 1.5 dx. i had an electric problem and toke it to the dealer after i get my car notice that ac is always working even thermostat set on heat. it starts blowing hot and cools down really quick even the engine heat drops down.
why??
Old Feb 24, 2014 | 04:26 AM
sstupid's Avatar
10 Year Member
Default Re: ac is always on even if its on heat
So, with your A/C button in the "off" position, your compressor clutch is still engaged?
Old Mar 3, 2014 | 06:18 AM
Kursatben's Avatar
Yes. Actually compressor kicks when I turn the fan on!!
Old Mar 3, 2014 | 11:13 AM
instrument's Avatar
Check the switch on the firewall that the slide connects to see if it moves when you slide the interior lever.
Old Mar 3, 2014 | 12:03 PM
Former User's Avatar
If you unplug the A/C thermostat or the A/C pressure switch, does the A/C still run?
Old Mar 3, 2014 | 03:51 PM
sstupid's Avatar
10 Year Member
I hate to ask, but is the AC button in the "off" position, meaning it is poking out and the blue light on the button is not lit?
Old Mar 6, 2014 | 09:42 PM
slowcivic2k's Avatar
Good point.
Old Mar 8, 2014 | 09:44 AM
90RioEF's Avatar
Compressor will run on defrost. If you mean it's just always blowing cold, move the temp back and forth and listen for the door to move, and you should feel the resistance. Do it kinda forceful
Sent from my LG-P769 using IB AutoGroup
hfelix71
Mar 24, 2018 05:17 AM
Single-Cam
16
Feb 10, 2016 07:23 PM
OldSchoolFool
May 12, 2015 02:08 PM
Sketch_hs
Aug 21, 2007 11:38 AM
old man honda
Apr 14, 2006 07:01 AM
