Procedure to check condenser fan relay
Old Feb 23, 2014 | 02:32 PM
bantum1cwa's Avatar
Default Procedure to check condenser fan relay
How do I jump the condenser fan relay with my multimeter. What are the settings for the multimeter to make it act as a jumper wire and should the ignition and a/c be turned on after I remove the relay and before I jump the connection inside the underhood fuse box?
Last edited by bantum1cwa; Feb 23, 2014 at 05:47 PM. Reason: To clarify that I will be jumping the relay connection not the relay itself.
Old Feb 25, 2014 | 08:51 PM
slowcivic2k's Avatar
Default Re: Procedure to check condenser fan relay
Jump pins 30 and 87a of the relay, your fan should operate. If not, check the fuse and the motor by jumping battery power to the fan and providing a ground.
Old Feb 26, 2014 | 01:50 AM
holmesnmanny's Avatar
You can also just swap it with another relay that looks the same. Relays of the same shape all act the same.
Old Feb 26, 2014 | 07:10 PM
fcm's Avatar
fcm
Old Fart
The tool everyone should have, and can afford...
No, neither the ign. or A/C have to be on. 94
Old Mar 5, 2014 | 06:06 AM
bantum1cwa's Avatar
LOL Thanks. That's exactly what I used. The fan didn't come on so I jumped the fan motor and it didn't start. I went ahead and replaced the fan assembly. Everything seems to working fine so far.
Old Mar 5, 2014 | 06:12 AM
bantum1cwa's Avatar
I jumped the relay and since the motor didn't start, I jumped the fan motor. It didn't start so I replaced the fan assembly and all is well. Thanks for your input.
Old Mar 6, 2014 | 07:59 PM
Be sure to post your entire process to help others out.
clowery89
Jun 23, 2010 06:17 AM
Ldo
Dec 8, 2008 11:43 AM
The Destroyer
10
Apr 21, 2006 01:19 PM
Taikonaut
Nov 4, 2005 11:26 AM
Nos4R2
Jan 26, 2003 09:40 PM
