95 Nissan Maxima, does it have a coil on each cylinder?
Old Feb 23, 2014 | 11:47 AM
dderolph's Avatar
Default 95 Nissan Maxima, does it have a coil on each cylinder?
My son has a '95 Maxima. I am not familiar with Nissan cars but I generally have more automotive knowledge than my son, who lives in another state. Based on what I've heard or otherwise learned, the Maxima has a coil on each cylinder, as opposed to one coil for the whole ignition system.
My son was told by a mechanic that a coil is bad but the mechanic said he could not determine which one was bad because his electronic diagnostic device would not work with a '95 Maxima; perhaps this was due to the age of the car.
First, can someone confirm that this car has a coil on each cylinder? And, second, if that is correct, can the faulty coil be identified by some method not requiring electronic diagnostic equipment? For example, could it be identified by disconnecting one plug wire at time and observe the affect on the engine?
Also, is replacement of one coil that is determined to be bad a feasible solution, as opposed to replacing all of them?
Old Mar 28, 2014 | 01:56 AM
P-M-B,93EXsedan's Avatar
Default Re: 95 Nissan Maxima, does it have a coil on each cylinder?
I will be surprised if Nissan had Coil on plug back in the 90s. Accords didnt get that until 2003
Old Jul 13, 2015 | 04:09 PM
Jared's Avatar
95 Maxima was definitely coil on plug.
95ninjaturtle
Dec 15, 2008 08:18 AM
Aquafina
Apr 19, 2006 04:52 AM
Revolver
Aug 28, 2005 12:23 PM
Redline130
Aug 8, 2001 12:31 PM
