1993 Civic Si Tail Lights Staying ON
Old Feb 22, 2014 | 03:03 PM
SiCivicHB1993's Avatar
Default 1993 Civic Si Tail Lights Staying ON
Hello,
I have some sort on an electrical issue. My car has been sitting for a long time the reason I parked was for 2 reasons 1) Revving Issue (ISSUE RESOLVED) and 2) Tail Lights were staying on which would drain battery unless you removed neg. battery cable which is what i did to try and save new battery. I recently starting working on it again - got revving issues fixed. I had to make a run to an auto parts store and left battery cable connected - when I returned battery wouldn't crank car - I tried jumping it but only taillights came on but no lights on dash at all. I thought maybe the lights were draining the little bit of power it was getting so i decided to pull fuse for them. The fuse was located in the engine bay near battery labeled STOP. I pulled fuse and brake lights went out. I go back in car but once again no lights, bells or whistles. I got to looking in the same fuse box and i noticed that the 80amp BATTERY fuse had also popped. Finally I went back to auto parts store bought new 80amp and 20amp fuses replaced them both and went to connect neg. battery cable back up and POP it instantly blew out battery fuse again. What gives?
Old Feb 22, 2014 | 03:05 PM
Former User's Avatar
Default Re: 1993 Civic Si Tail Lights Staying ON
You must mean brake lights rather than taillights.
Check the rubber stopper at the top of the brake pedal. It likely fell out.
Are your battery connectors reversed? What work was recently done on the car?
Old Feb 23, 2014 | 10:48 AM
BryanEG8's Avatar
THIS right here, I had the same issue I was trippin out having to drive through a canyon on the way home from work one night thinking what the ****, is something wrong with my brakes. but yea it turned out it was just the rubber stopper, what made it worse for me was earlier that day I had locked up the brakes to avoid getting hit by one of those camera lights, so I thought my brakes were sticking or something,
Old Feb 23, 2014 | 05:03 PM
Yes! It was the sensor on brake pedal! Thanks!
Old Feb 23, 2014 | 05:05 PM
Sounds like a tense situation especially coming down a mountain!
Old Feb 24, 2014 | 08:44 AM
BryanEG8's Avatar
yea it was I started trippin myself out thinking that I can smell my brakes and ****, it was pretty intense
Old Jun 11, 2016 | 08:59 PM
whatr.udoing's Avatar
Thanks for the tip. My car and battery were dead and heavy drain trying to charge it. Had to disconnect the battery to charge it. When reinstalled I noticed the brake lights on. Checked here and you guys probably saved me hours if not days of troubleshooting. Now to find one of those little hard rubber stoppers.
Old Jun 12, 2016 | 09:03 PM
Sharpie14l's Avatar
Easiest thing to do is but a small bolt and nut through the pedal where the rubber peice goes. He'll I used pennies and electrical tape for a few weeks on my DA integra lol. My current civic has a plastic push-in pin with a zip tie on it so it can't fall out.
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
JasonYo
Apr 11, 2011 04:47 PM
ludachrisvt
Sep 22, 2008 11:01 AM
egcivic
Jul 21, 2006 07:16 PM
