is it any good?;using a spoon 71 celcius thermostat?
Old Feb 22, 2014 | 03:22 AM
alanvtec's Avatar
Default is it any good?;using a spoon 71 celcius thermostat?
i planned to replace the standard d16 sohc vtec thermostat (88 degree celcius) to spoon thermostat (71 degree celcius)..
my concern is:
1-is it any good to use the spoon thermostat to enable the fan radiator to function early than before
2-do i have to replace the fan switch as well?if yes,does 78 degree celcius fan switch ok?
Old Feb 22, 2014 | 06:37 AM
Freemananana's Avatar
Default Re: is it any good?;using a spoon 71 celcius thermostat?
Is your car overheating? There is no reason to put in a lower temp t-stat. There is no reason to run the spoon thermostat.
Old Feb 25, 2014 | 05:04 AM
alanvtec's Avatar
yes..i notice that my thermostat only opens at 93celcius..by right that thermostat should open at 86celcius...i have replaced the original thermostat and the fan switch but same problem remains..coolant are good..fan also ok..but it spins late..
Old Feb 25, 2014 | 08:44 AM
Is there air in the coolant system? How are you telling the temp?
Old Feb 25, 2014 | 01:23 PM
ProjetEF's Avatar
i think it dosen't worth it for a street car. I would put this on a intensive race car.
Mike Panic
13
Oct 6, 2004 10:15 PM
ithrowpoop
Feb 15, 2004 02:47 PM
underrated99si
Jun 20, 2002 06:06 AM
Lei Siew Long
May 21, 2002 03:53 PM
ithrowpoop
Apr 3, 2002 05:14 PM
