93 del Sol - will these wheels bolt up?
Old Feb 21, 2014 | 07:51 PM
LoveBrisk's Avatar
Default 93 del Sol - will these wheels bolt up?
I've found a set of MB wheels Seven X at a junkyard. They're in good condition. The bolt pattern reads 5x100 and the del Sol is 4x100... But these look to be universal.. If that's the case then will they bolt up? And will they rub or cause issues with turning. I'm not looking for any style of racing or benefits.. Just a way out from steelies
Old Feb 21, 2014 | 09:32 PM
RichCMemphis's Avatar
Default Re: 93 del Sol - will these wheels bolt up?
You will have to get them re drilled to a 4 lug pattern. I believe those wheels have a high offset to.
Old Feb 22, 2014 | 04:39 AM
LoveBrisk's Avatar
I don't quite understand the patterns here. If it won't work with a 93 del sol.. Then will they work with a 03 civic?
Old Feb 22, 2014 | 05:09 AM
No bc 2003 civics are also 4 lug. The only 5 lug civics prior to 2006 are CTR
Old Feb 22, 2014 | 05:58 AM
LoveBrisk's Avatar
Here is a picture of them. They're bolted to a 4 lug pattern car now.
Old Feb 22, 2014 | 06:17 AM
toyomatt84's Avatar
Sanji
Those aren't 5x100. Those are 4x100 and 4x114.3 (two different bolt circles on one wheel face). Those will fit your car, but honestly... they're not worth anything and are fairly heavy for their size.
PS. Just because a wheel has a bolt pattern in the casting, doesn't mean that's the actual bolt pattern the wheel is.
Old Feb 22, 2014 | 06:21 AM
LoveBrisk's Avatar
Thank you!! I know they aren't worth much but they look much better than stock steelies. And they should work with my del Sol and my 03? They both have steelies.
Old Feb 22, 2014 | 06:39 AM
toyomatt84's Avatar
Sanji
They may not fit well on your '03 (they're a bit small), but they will fit your Del Sol just fine.
Craigslist is littered with wheel choices for cheap these days, if you search for 4x100.
mikeaitken
Jun 26, 2007 04:54 PM
Trky
13
Apr 11, 2007 02:34 PM
verseone
Feb 9, 2005 08:52 PM
titaniumB20
Sep 19, 2004 10:33 PM
scottscotland
Mar 9, 2003 04:32 AM
