Car cranks but won't start
So I came with a problem with my 95 teggy b18b1 all stock motor that I just bought a couple months back.. The car didn't wanna turn on one morning last week so I been braking my head trying to find out what it is.... So this is the problem that started it all one one day it took a while to start and crankd for a couple seconds before turning on but turned on so the next day in the morning it just cranked but didn't start. So first thing I did was check the dizzy and it was good but was not getting spark so I checked voltage and found that the coil was bad because I was not getting any spark so I ordered a new dizzy so I replaced it along with spark plug wires and spark plugs and didn't wanna start ether but now I have spark and voltage is good. I checked fuel and I get fuel I checked the fuel injector sensors and they blink wen you crank the car ,I also checked the main relay and it clicks when you open the ignition, checked all the fuses and they are all good checked timing belt maybe it was the belt but it's good, so the last thing I did was I used a paper clip to check the ecu and the check engine stays on and don't blink.. Has anyone out there had the same problem I'm having, as I was reading if the check engine stays on and don't blink wen you are using the paper clip method it's a bad ecu or main relay but my main relay clicks so I'm guessing is a bad ecu.?
cream1316
May 15, 2011 09:32 AM
quad
20
Mar 14, 2007 05:16 AM
