1996 Civic no spark doesn't seem to be the igniter or ecm
I know there are other threads with no spark issues and that I'm a noob here that will prob be told to search the previous threads (which I did). I have troubleshot the issue and don't know where to proceed. Here goes
No spark at plugs
No spark at Dizzy
Changed out igniter
Changed out ECM
Non of this did anything
Checked for signal from ECM as well as power to the igniter and nothing on both.
I'm at a loss and don't know what my next step would be. Please help
No spark at plugs
No spark at Dizzy
Changed out igniter
Changed out ECM
There is no voltage in any of the ignition system. I did a crank test on the pos wire on the igniter, no volts. Did another crank test on the Yellow with Green stripe wire of the 7 wire distributor connector still nothing.
Describe exactly how you are testing for voltage. Are you using a multimeter?
Did you test the Blk/Yel wire?
How did you test for spark at the plugs?
Sorry by crank test I mean while it was being turned over by the starter. I used a spark tester to test at the plugs, dizzy and coil. I used a diff website to do a step by step test but not sure if ppl would get pissed about posting another sites link on here.
Describe exactly how YOU tested for voltage at the Blk/Yel wire in the distributor.
Never crank the engine with the distributor cap removed because you will blow the coil inside the distributor. Just turn the key to ON(II) rather than ON(III).
Ah well I might have mucked that up a bit then. I had the cap off the distributor using a multi meter with neg side on the partially exposed blade of the Yellow with Green stripe wire pos end of MM had on the pos batt terminal. The pos and neg wires going to the ignitor I used the MM on pos on pos, neg on neg.
No voltage was detected in on(II) or on(III)
You did the voltage test incorrectly.
For the Blk/Yel wire, do this:
- Remove distributor cap, rotor, and inner cover to expose the coil and ICM wires. Do not unplug the distributor connector.
- Turn key to ON(II).
- Set multimeter to read DC volts.
- Touch red meter probe to the Blk/Yel wire and the black meter probe to the body of the transmission.
- What voltage do you read?
New coil (valucraft from autozone) reads out of spec also
0.01 A-B
10.69K A -secondary winding terminal
Should I save the time of even installing it?
0.01 A-B
Describe how exactly you are doing the Ohm tests.
Post a picture of your multimeter, how it is set for the tests, and how the probes are installed.
The 20K setting is fine for the secondary winding test, but not the primary winding test.
Upload your pictures to PhotoBucket or ImageShack, etc. and then paste the IMG code into your post.
Click the spark link in my signature for testing details.
How do I post a pic here? All I get is enter URL
[IMG]
