Car Not starting
Old Feb 21, 2014 | 09:59 AM
eman96's Avatar
Default Car Not starting
So sometimes my car doesn't want to start at all, it would turn over fine but won't turn on, and sometimes it does but dies quickly. When it does i usually have to give it some gas so it doesn't die, and I also notice that while I'm running my car and I stop/ Park it or Turn it on it would idle real low. I appreciate any help.. 93 DA9 Stock B18A1
Old Feb 21, 2014 | 04:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: Car Not starting
Check fuel pressure.
When was the fuel filter last changed? 94
Old Feb 22, 2014 | 02:33 AM
eman96's Avatar
I am actually no sure, I haven't owned the car for too long. Also it got worse know, it died like 3 times while I was trying to get out of the parking lot which I never did...
Old Feb 22, 2014 | 02:46 AM
eman96's Avatar
Now* And how can i check the fuel filter? Sorry I'm a complete Noob .
Old Feb 22, 2014 | 07:35 AM
tamboo's Avatar
10 Year Member
just crank it over and pull a sparkplug to see if it's wet with gas.
or just replace fuel filter as it needs to be done every 2 years/30k miles.
Old Feb 22, 2014 | 10:17 AM
eman96's Avatar
I'm actually thinking i might have a bad Distributor. Can a bad Dizzy cause this?
Old Feb 22, 2014 | 04:27 PM
fcm's Avatar
fcm
Old Fart
Yes.
You will need a fuel pressure gauge to check fuel pressure, pulling a spark plug will not tell you what the pressure is, however it can tell you if the injectors are "firing" or not.
So start by looking and listening, when engine will not start, turn ign. switch on to the run position, [not all the way to start] and look and listen.
What should happen is....
The cluster will light up including the CEL.
At the same time.
There will be two(2) "clicks' from the PGM-FI Main Relay, [it will sound like one click as they are very close together].
The fuel pump will start priming, you can hear it.
After no more then a few sec. there will be a 3rd click from the PGM-FI Main Relay and the fuel pump will stop priming.
At the same time the CEL will go out.
If the above is not happening pull the PGM-FI Main Relay and chack for the 3 powers...
A 12V constant, hot at all times.
A 12V switch, hot in run and start.
A 2nd 12V switched, hot only when cranking to start.
If not, check fuses.
Make sure the black lead is a good ground, full continuity to chassis ground.
If not check the ground(s) at the termostat housing.
If you have both the powers and ground....
http://www.tegger.com/hondafaq/mainrelay.html
http://techauto.tripod.com/mainrelay.htm
Pick up an HEI spark tester, $10-$15 at any auto parts store, and test for spark on all four cylinders.
That should keep you going for a bit.
Replace the fuel filter, and test the fuel pressure, just buy and permanently mount a fuel pressure gauge, makes a good diagnostic tool in the future and can be found for under $50.
Also, if you are going to work on your car yourself buy a manual, even just a Haynes will help a lot. 94
Old Feb 25, 2014 | 05:30 AM
eman96's Avatar
Yes.
At the same time.
Thanks a lot man, I checked everything and thankfully fuel was good and grounds etc.; I took it to the shop and effectively it was my Dizzy that went bad, so now it's all fixed. Thanks
StockDC2
Apr 22, 2012 03:35 PM
kornkid21792
Feb 14, 2010 02:06 PM
Jibin
Jan 16, 2010 11:52 AM
bignosewhipper
16
Jul 3, 2008 05:38 PM
red92EG
Jan 16, 2006 07:59 PM
