What trans fluid to run in b series liberty face plate gears
Old Feb 21, 2014 | 06:54 AM
blade0314's Avatar
Default What trans fluid to run in b series liberty face plate gears
What's up guys just wanted to see what fluid all you liberty face plate b series trans guys were running ?
Old Feb 21, 2014 | 07:45 AM
Turbo-LS's Avatar
Default Re: What trans fluid to run in b series liberty face plate gears
Relight lightweight shockproof, Torqo Mtl prob be good fluids it's still stock gears.
If you don't mind me asking what the face playing set you back and turn around time.
Old Feb 21, 2014 | 07:52 AM
blade0314's Avatar
Might look into torco rtf but I think I'm gonna use honda manual trans fluid
What alot of guys dont realize is that thick **** wont circulate properly. 75-90 is gear oil its thick. Its not going to lubricate the needle bearings properly. They suggest that **** assuming you will be tearing down the trans and replacing bearings etc periodicly. The oil galleys are very tiny the thick stuff wont circulate properly. Thats one reason hondas stuff is thin like water. Plus less resistance for fuel economy/hp
Faceplating just gets rid of the dogteeth and replaces the with larger pieces. Trans fluid has no effect on that.
Faceplating the oem helical gears doesnt change anything as far as the fluid is concerned. If it was a dog box with straight cut gears then maybe consider running thicker fluid but knowing it will require more maintenance or at least checking over. Still dont think id run gear oil though
Gear oil is good to use for high temp applications like rear diffs etc. Or in some trans which were designed to use the thick stuff. Honda trans lubrication system is designed to use thin stuff
The face plating cost me $700 without any metal enhancements and they assembled the gearset for me plus shipping and your gonna need the speed factory scha with this which is $400
Old Feb 21, 2014 | 08:07 AM
tepid1's Avatar
I'd use Torco RTF or Motul gear oil.
The thicker stuff like shockproof Redline has great stiction, which is why I like it, but you want something with more fluidity to actually cool the gears, especially OEM ones.
I hope you plan on removing 5th and installing a brace.
Old Feb 21, 2014 | 08:23 AM
blade0314's Avatar
I hadn't really thought about removing 5th gear for a brace this is for a all motor application, thought that the brace was for high hp turbo cars which usually have the shaft separation issue that make like 700 hp+
Old Feb 21, 2014 | 08:30 AM
parts@synchrotech's Avatar
With the stock gears I would go with Torco RTF
Old Feb 21, 2014 | 08:35 AM
AZ_CIVIC's Avatar
I use Redline with my Face Plated Gear set.
Old Feb 21, 2014 | 08:37 AM
blade0314's Avatar
Thanks for the suggestion I'll have to look into that
Old Feb 21, 2014 | 09:00 AM
Turbo-LS's Avatar
Chris I agree but the redline lightweight has more fluidity. I wouldnt run standard redline shockproof with stock gears.
Old Feb 21, 2014 | 10:12 AM
1HGEJ2's Avatar
What do u prefer with albins gear. ? And stock s9b diff
Old Feb 21, 2014 | 10:16 AM
Natural Aspirations's Avatar
Why would this require an upgraded scha?
Old Feb 21, 2014 | 10:32 AM
blade0314's Avatar
It is not necessary to have the SF scha but with dog engagement type transmissions the possibility of 1-2-1 or 2-3-2 so it's strongly suggested to get the SF scha to help eliminate that
Old Feb 21, 2014 | 11:11 AM
AZ_CIVIC's Avatar
Add a T1 Shifter and you are golden.. I never have to worry about shifting with that setup.. The T1 shifter and Speed Factory SCHA basically shift itself into the correct gears.
Old Feb 21, 2014 | 11:22 AM
blade0314's Avatar
That's $$$$$ lol ... $80 oem shifter ftw! Lol
Old Feb 21, 2014 | 11:45 AM
AZ_CIVIC's Avatar
True that, it's pretty expensive..There was a guy out at IFO a month ago who just did the Liberty Face Plated gear set, had the Speed Factory SCHA and did a 1-2-1 using stock shifter..
I am sure plenty of people use the OEM shifter with no problems and this guy probably just had bad luck, he literally just finished the tranny and was running it the first time..
Old Feb 21, 2014 | 12:05 PM
blade0314's Avatar
**** id be pissed!!! ive never had any problems before with my stock shifter on my stock oem gearset, i actually liked my oem gearset only got faceplate cuz alot of people recommended it so well see how it goes
Old Feb 21, 2014 | 12:47 PM
AZ_CIVIC's Avatar
Yeah I ran my stock CTR tranny for 7 years 500 plus horsepower.. Sold it got a GSR trans, Mfatory Differential, Liberty Face Plated gear set, Speed Factory SCHA, Liberty Cuff, T1 shifter and solid mounts.. wish I would have done it years earlier LOL..
Old Feb 21, 2014 | 07:31 PM
Aquafina's Avatar
Torco RTF. Do not use Honda MTF.
Old Feb 21, 2014 | 07:34 PM
blade0314's Avatar
Any reasoning as to why not to use honda MTF ?
Old Feb 21, 2014 | 09:27 PM
choadsi's Avatar
Torco RTF....I run a face plated setup and blew 4th to pieces on Honda MTF on the dyno. Turbo car not all motor but still better to be safe than sorry. I'm running Torco RTF in my street car with stock trans + many dyno sessions and it still shifts like butter
Old Feb 21, 2014 | 09:53 PM
turbo-2nr's Avatar
the Honda MTF they now sale is not the same as it use to be they removed alot of the friction modifiers the help the problems they where having with the 2001+ cars, for oem gear sets/syncro we run one qt Honda MTF and the other QT some type of synchromesh weather it be Pennzoil, Redline or RP the Honda syncros need the thin fluid and friction modifiers to operate properly.
As far as face plated gears viscosity can be higher and you want it to be higher to cushion the dog engagement, plus with something thicker than Honda MTF it will stick to the gears I would suggest redline light or super light weight, but don't let the viscosity fool you even thow they are rated at 75W140 and 75W90 they still have a low fluid friction and will make it to the bearings fine
Old Feb 21, 2014 | 10:50 PM
Aquafina's Avatar
Honda MTF is too thin and lacks the proper EP additives for high power/high RPM setups.
Old Feb 22, 2014 | 07:34 AM
NAH2B's Avatar
lol that's funny considering hes been on Honda mtf for 2 seasons working flawlessly.
and hes not the only one
Old Feb 22, 2014 | 07:45 AM
NAH2B's Avatar
yes Honda changed their mtf several years ago amidst all the customer complaints of the k series trans having shifting problems. although most dealerships service departments and techs simply used bulk 5w30 when they performed fluid changes up until that point. then came along all the shifting problems etc with the k trans. they changed the fluid. the newer fluid is even thinner than the older stuff. some guys add syncromesh and swear it works. other guys have tried syncromesh and it doesn't make a bit of difference.
im sure torco rtf works great. so does Honda mtf.
Old Feb 22, 2014 | 07:47 AM
NAH2B's Avatar
trans fluid is not the reason you broke a gear on the dyno. I don't know of many guys "bangin" gears under load on the dyno
