VSS not working - easy fix
Old Feb 20, 2014 | 09:09 PM
oliebollen's Avatar
Default VSS not working - easy fix
A while back my speedometer started to drop to 0 intermittently and then kick back in and give me a reading. Then it would conk out and then start working again and the same thing over.
If you open up the VSS you'll find a wheel (which is positioned horizontally like merry-go-round) and a spring in the middle with a ball bearing in the top of the spring which makes contact with the top of the VSS (the spring/ball bearing must be some kind of electrical contact).
What I noticed with the VSS that wasn't working properly is that the ball bearing at the top of the spring was worn down completely flat. On my good VSS the ball bearing was hardly worn and would clearly make good contact with the top of the VSS if the top were on. My thought is that by simply stretching out the spring on the broken VSS (so that it can make good contact with the top of the VSS) it would start working again.
I haven't tested this yet but I think it would work.
Old Feb 20, 2014 | 09:41 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: VSS not working - easy fix
I would think replacing the ball bearing would be a better solution. Just need to know the size.
Or have a day at the junk yard popping open VSS's and dropping the ball bearings into your pocket.
Dumped89Si
Aug 21, 2017 04:16 PM
s10cky
Jan 8, 2007 04:54 PM
MINT90EF
Jun 24, 2005 11:32 AM
DragII
Apr 30, 2002 10:21 PM
therealciviczc
Apr 9, 2002 03:19 PM
