JDM front Radiator support, NO NEED TO WELD???
Old Oct 29, 2002 | 05:59 AM
citanest's Avatar
New User
Default JDM front Radiator support, NO NEED TO WELD???
When I talked to the installer of 2 C-West PY R, he says he didn't have to weld the rad support. He found an alternative way and he can change back and forth with USDM front and JDM front without welding. I have seen the Front end in person and it fits perfect. The front end can withstand all the torture on the track without readjustment, plus the bottom line is those 2 cars are track-only cars. Anyone have any thoughts on that?
Old Oct 29, 2002 | 06:29 AM
citanest's Avatar
New User
Default Re: JDM front Radiator support, NO NEED TO WELD??? (citanest)
I don't know the steps, otherwise, I won't be asking for inputs.
Old Oct 29, 2002 | 06:43 AM
Mike M's Avatar
Founding Member
Not possible unless he is somehow modifying them. Some cars have Bolt on Rad Supports, so my guess is he is only using the top and center section of the Rad Support (All that needs to be used and is different) and modifying it so that it bolts on.
You still have to do some cutting of the Fender skirts for the JDM Headlights to fit.
Old Oct 29, 2002 | 07:42 AM
sgT's Avatar
sgT
Default Re: JDM front Radiator support, NO NEED TO WELD??? (Mike M)
On my car the lengths of the skirts were off so i do not think it would look right
if it were done in that fashion.
Old Oct 29, 2002 | 07:47 AM
AW's Avatar
AW
I remember Alan telling me this when he put the JDM front end on and it is indeed bolt on. The only problem I have with that type of set up is that the front rad mount support is a critical point of the chasis, if you don't weld it, it will most likely not be as strong as the stock welded support. Not sure how it would do in a front end crash.
AW
Old Oct 29, 2002 | 08:16 AM
Mikes01GSR's Avatar
Default Re: JDM front Radiator support, NO NEED TO WELD??? (AW)
Talk to him again and ask him how he did it!!
Old Oct 29, 2002 | 09:41 AM
KiLLa CaM 06's Avatar
Default Re: JDM front Radiator support, NO NEED TO WELD??? (Mikes01GSR)
i did mine without having it welded. put the bumper support on the radiator support then just bolt them up. fits perfectly. oh yea make sure u dont use a jack on the radiator support to jack up the car
[Modified by olskodumie, 6:46 PM 10/29/2002]
Old Nov 9, 2002 | 06:44 PM
Havokgsr
Guest
Posts: n/a
ask him how he did it ....does anyone have set by set instructions?
Old Nov 9, 2002 | 07:06 PM
uNF$@#!'s Avatar
welding on a rad support REALLY isnt a huge deal guys...i mean your going to be painting the entire front for 36/hour...why not just pay the 50/hour for the mech work for one hour?
heck, if you can spot weld, then you dont even need to pay someone to do it! ....
[Modified by Soup ****, 11:08 PM 11/9/2002]
Old Nov 10, 2002 | 10:30 AM
EndlessGarageEG6's Avatar
While putting my freinds front end on we used nuts, bolts, and a drill as an alternative to hold it on until we could have it welded properly.
Old Nov 10, 2002 | 07:42 PM
uber_nihilist's Avatar
Default Re: JDM front Radiator support, NO NEED TO WELD??? (Soup ****)
Because how do you know that the body shop will do a good job? Ever wonder why most autobody shops don't offer 3 year warranties like you would get on a new car? Because their work is unreliable. I know this, autobody shops have ruined many of my friends cars. Its not just as simple as walking in anywhere and having it done.
Anyway, you don't even have to weld on the "whole" JDM radiator support, or weld at all, because the only different pieces are the headlight section and the middle bar that holds the hood release mechanism. These parts you can rivet, screw, or weld on, once you have removed them from the JDM radiator support. Welding on the whole support is riskier and costs more money.
Pr-Type-R
Jan 24, 2009 07:50 PM
DC2_2
Welding / Fabrication
Jul 25, 2006 02:00 PM
kaj
Oct 30, 2005 07:23 AM
98cwtypeR
Feb 25, 2003 09:04 PM
junk yard sol
Feb 10, 2003 04:33 PM
