98 honda civic
Old Feb 20, 2014 | 03:01 AM
msbotwin's Avatar
Default 98 honda civic
I am going to do my best to explain my situation. I have a 98 honda civic auto , I drive 45 miles one way to work every night I have recently been experencing my car lose complete power while driving. The first two times I had been slowing down to turn and the third time I was slowing down to stop at a light and lost all power to the engine. My lights and radio still work. I have to try and start the car for about 2 minutes and then it will start again. While I am trying to start the car it turns over like it wants to start but it wont turn over for approximatly 2-4 minutes. There is no check engine light that comes on before it happens so I have no codes to read. I did take it to a mechanic to see if it threw a code and there was no codes at all.
Old Feb 20, 2014 | 06:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: 98 honda civic
Most common intermittent loss of engine, [running] is the PGM-FI Main Relay...
http://www.tegger.com/hondafaq/mainrelay.html
Next most common is the coil, heat will cause it to fail, once cooled down it will work again.
Next is connection problems, [loose] to/from the coil and ICM.
And last but not least, [should be the first thing you do] as with any suspected electrical issue, is grounding, check/redo your main grounds, [batt. to chassis, chassis to engine, VC to rad support and thermostat housing ground(s)] DO NOT just eyeball the connections, disconnect/clean/reconnect. 94
Old Feb 20, 2014 | 09:55 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Does it stumble before dying out,or does it simply die?
MA70SUPRA
Jan 20, 2018 05:24 AM
gorilla47
Mar 2, 2017 08:39 AM
electrones
Honda Civic (2006 - 2015)
Oct 24, 2013 03:03 AM
ERIC1
Oct 29, 2012 07:09 PM
mhng
Apr 23, 2005 06:44 AM
