97 Odyssey Idles rough when in gear
My Odyssey shakes when idling
I replaced the rear and front motor mounts and that helped a lot
But
When it's in gear the vehicle shakes ..sometimes exaggerated sometimes more subtle ,,,,,,,when it's in neutral there isn't much vibration
I am not sure if this is part of the problem but the idle fluctuates too
It gets very slow and then speeds up again
A Mechanic mentioned two things The throttle positioning sensor and the Map sensor
We replaced the rotor and cap and changed the fuel filter
But
