timing question
Old Oct 29, 2002 | 05:26 AM
APEXI Si's Avatar
Default timing question
I know this is a horrible qestion...I searhed too. Well anyways.. I was putting my zc back together and I what postion should the cam gears being in compared to the crank pully. Thanks.
Old Oct 29, 2002 | 06:58 AM
altoid's Avatar
Default Re: timing question (crx616)
should be in your manual you own right? if its sohc zc its timed like a d16a6 if its dohc its timed like the 2nd gen teg..though im not certain on the latter, so don't quote me on that...
Old Oct 29, 2002 | 07:27 AM
APEXI Si's Avatar
Default Re: timing question (altoid)
I lost the manual. What I really trying to find out is should the two arrows be pointing up when the red dot on the crank pully is timed right. Sorry it is hard to explain.
Old Oct 29, 2002 | 07:29 AM
USDM 4G VTEC's Avatar
no
u need to take crank pulley off and alignt the mark on the crank gear thingy.. tothe mark on the block... then alignt the head to its marks... theres one mark on the block to align to the crank gear... and another 3 on the head...
h23vtec_dc2
Mar 7, 2010 12:20 PM
sean burke
Apr 20, 2009 04:23 PM
matmcg
Jun 15, 2008 09:54 PM
ITR9788
Jan 20, 2004 02:51 AM
dpo95si
Aug 17, 2002 08:11 AM
