13 or 15inch wheels for radials
Looking for some cheap 13 or 15 inch wheels im thinking im gonna put nitto 215/50 or 225/50 drag radials I have a 89 ef hatch stock brakes need something that will fit and will clear the caliper. Do any oem 15's fit 215 tires? Im on a budget so whatever is cheap but I will not go with xxr
exospeed 13" will fit your stock brakes, they fit 10.5" brakes M&H 24.5 drag slicks
I am using kosei k1 15" with NSX 11.5" brakes M&H muscle car tires, 236/60/15 or 25.4
i use vx wheels with hossier r6 185/60/13 tires with success. i cut 2.0 60ft's with them and seem to work decently on the street.
for a budget these work pretty good. check out diamond or aero wheels as well
http://www.summitracing.com/parts/cr...0500/overview/
versus the $300-$400 per rim top dollar forged aluminum drag wheels yeah. 14.5lbs is the same weight as some fat fives or meshes or aftermarket 15's. the key word here is "CHEAP" as the OP asked for. yes vx wheels are light, about 10lbs, but you'll only be able to run at very most a 205 on them if your lucky. i'll take the extra 5lbs and run some real meats
a couple threads i found. not tryin to start an argument just wanted to put the info out there.
https://honda-tech.com/forums/drag-racing-36/vx-wheels-slicks-1807083/
https://honda-tech.com/forums/drag-racing-36/civic-vx-rims-slicks-2183157/
Fuster_Cluck
Jan 17, 2004 05:06 AM
