Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda trying to sucker me?
Old Feb 19, 2014 | 07:41 AM
Jordan Drummond's Avatar
Icon2 Honda trying to sucker me?
So I have a 2013 civic si supposed to be "fully loaded" except I noticed my tire was low waiting for the tire pressure light to come on, only they didn't install it, so I'm looking up specs and noticed Tire Pressure Sensor came up a lot, is this a stock feature Honda's trying to weasel there WAY out of? Also I think I'm missing ABS and EBD. Another thing I noticed on the MiD matenace screen I notice in other photos it has air filter life but my matinance only pops up with oil life and tire alignment. Should I take my civic back and bitch hard or are these just hidden features they don't mention you to get?
Old Feb 19, 2014 | 08:15 AM
m_shake's Avatar
Default Re: Honda trying to sucker me?
Is the car brand new from the dealer or used?
Old Feb 19, 2014 | 08:16 AM
I just spoke to Jonker Honda's head technician and he says the no civic comes with the tire pressure sensor but I have 2 websites telling me different, both are Hondas websites and not some 3rd party spec site.
Old Feb 19, 2014 | 08:17 AM
Brand new 15 Km fresh from the factory, they didn't even have enouth time to add there gay company decal, don't need no Jonker on my car
Old Feb 19, 2014 | 08:23 AM
m_shake's Avatar
If you're in america all new cars have TPMS because the government decided we are too ******* dumb to keep an eye on our tires. Either the car sat on the lot for along time and tire pressure went down enough for the light to go on OR the technician doing the PDI didn't set it up correctly.
Old Feb 19, 2014 | 08:24 AM
m_shake's Avatar
Also if you haven't already it might be a good idea to read your owners manual to answer some of your questions.
Old Feb 19, 2014 | 08:31 AM
Aw no I'm Canadian, I guess they decided we needed a big touch screen deck more than knowing the pressure of our tires, I only had it 3 months, got à nail in the tire, got it replaced for free because of warrenty
Old Feb 19, 2014 | 03:22 PM
97emsedan's Avatar
Jordan, Canadian cars don't have TPS as standard equipment. It is a dealer installed option. The EBD and ABS are standard equipment on all Civics as they are required safety equipment.
The air filter warning is not going to go off often as the filter is new and you don't drive on gravel roads much, I would presume.
The maint minder will be your reminder for scheduled maintenance. When the wrench pops up as you start the car, it will give you a code. a1 is an oil change, B1 is oil and tire rotation..etc..read the manual.
Old Feb 19, 2014 | 04:52 PM
DaveSi677's Avatar
pretty much spot on!
Old Feb 21, 2014 | 11:51 AM
outgunned's Avatar
yea my 2009 civic si is doing the same thing with the tire pressure indicator.
Old Feb 21, 2014 | 08:03 PM
vladd's Avatar
The maint minder
I'm pretty sure the maintenance minder system has no way of sensing whether you're driving on a dirt road or a paved one.
Old Feb 22, 2014 | 07:46 AM
97emsedan's Avatar
No, the maint minder won't. But the air flow for the interior cabin and the engine will...there are sensors for the measurement of airflow to the engine....
Old Feb 23, 2014 | 12:32 AM
vladd's Avatar
There aren't any sensors that I know of in or around the cabin air filter (at least on the 06-11 Civic). As for the motor air filter, which sensor is it that looks for dust?
Old Feb 23, 2014 | 09:44 AM
97emsedan's Avatar
The engine MAF sensor will throw a code when the filter is clogged...and no, there is no sensor for the cabin filter, just your eyes and nose..
The engine filter should be checked visually at least once per year to ensure it isn't clogged or worse, holed..
I have had my Si for going on four years now, changed the engine air filter last summer. Preventative maint is much easier that corrective maint.
Old Feb 24, 2014 | 01:12 AM
vladd's Avatar
I now have no idea what you're trying to say. First you were saying the car could sense when you drive down dusty roads. Now you're saying it can't.
Old Feb 25, 2014 | 05:19 PM
97emsedan's Avatar
Ok, I didn't use the right words...the air filter is not sensored. The only way you can tell when it gets really fouled without opening the housing and getting eyes on, is to get a code from the MAF sensor. It is in the intake pipe and it detects Mass Airflow...if the amount of air flowing into the engine drops, your filter is dirty...the filter fouls much much more quickly when you are off asphalt hence gravel roads...
Old Feb 25, 2014 | 08:49 PM
bwong247's Avatar
damn
Barbie Pitts
Honda Civic (2016 - Current)
12
Mar 22, 2023 04:40 AM
Frank S
Honda Accord (2013 - 2015)
Sep 25, 2018 10:50 AM
angie54
May 2, 2013 03:00 PM
Krator
Dec 29, 2011 09:48 AM
EF_9
Jan 18, 2008 07:19 PM
