2.5" to 3" options
I have a 2.5" downpipe since my T3 garret has a 4 bolt 2.5" exhaust side. Just made sense to keep it 2.5". But my exhaust I have is a 3" Thermal R&D (actually just bought this) and I am wondering how to mate the 2 together. I haven't sized the Thermal Exhaust up under the car to see how much room/space I have to work with, but I am looking to see what my best option would be for connecting the two.
Should I go with a 2.5" or 3" flex pipe?
Am I stuck with a 2.5" pipe expanded to 3" to mate the two together?
Is there a way to use a vband to mate the two?
It's really tough finding some shots of this exhaust on an EF. I'm more of a visual learner and I'm having a tough time wrapping my head around exactly what the best way to go about this would be.
I know I should mount the exhaust and go from there, but I am hoping to order some more parts so I can get the exhaust installed sooner than later. This car is awful with a open downpipe and I hate it.
Thanks
EDIT: I personally know how to MIG weld and that's what I have at home. I have access to a TIG at work, but I've never used it. If I have to get some help with some welding, I can find someone to give me a hand.
Thanks
i would redo the downpipe and weld a 2.5-3" transition right on the 4 bolt flange. If you want to keep the 2.5" downpipe, the only way to get to 3" is using a transition...maybe weld it to the end of the downpipe, then use a 3" vband to connect the downpipe to the exhaust
I will probably just transition from the end of a 2.5" flex pipe to the 3" thermal exhaust. The downpipe fits well with my current manifold, I'm not sure a 3" downpipe with the adapter on the exhaust housing of the turbo would work. At least not how I feel I can fabricate it. I'm sure people have welded 3" vbands to their turbos and ran just fine. But I don't think that's up my alley.
Definitely appreciate it!
i get all my transitions i use from http://www.mandrel-bends.com/catalog...less-2681.html
Your paying for quality tho. this is stainless, those are probably galvanized steel and are used in a tube expander instead of a rolled cone.
Thanks though
Then what will work just fine. Good luck!
Main reason I bought this exhaust was due to my local shop sucking hard and the flange they welded on snapped and well.. long story short, my cat back isn't so hot around that area right now.
So I did it. Excuse the ugly welds. Function>Form?
Here we go. I put on my Thermal Exhaust this weekend. This is the 3" Turbo exhaust from Thermal. I'm pretty pleased with it. My welding, not so much. This is what happens when you are a novice and you take a 3 month break.
Hanging it was pretty easy.
Connected the B pipe
Hung it up
And here is my gap
Time to fabricate something.
Sizing it up, going to cut it. As you can see this piece slipped into the other. It makes for an easier weld. It also means it can adjust. So I cut it short and pulled the pipe out to get the exhaust size. I also rotated the flange to make it all match up while under the car.
Here it is after the test fit
Here it is on the car.
That's fully welded up. I gave it the old sound test and it doesn't sound like there are any large leaks. But I'm going to grind back the welds (to look for holes) and run them again just to be safe. I have a video, but I'll have to upload it another time and post it here.
All in all. I'm happy with it. I am taking it back off like I said. I have to paint it and install my O2 bung for my wideband.
Hung it up
And here is my gap
The main point was to show case what I used to go from Thermal's 3" Turbo Exhaust to my 2" B16A header. This is what I plan on doing for my 2.5" downpipe too.
b_ron007
Oct 28, 2004 01:49 PM
