D15Z6 upgrade?!? I want loud and fast :DD
Old Feb 18, 2014 | 03:44 PM
benderinn333's Avatar
Default D15Z6 upgrade?!? I want loud and fast :DD
What too do?
Im getting a exhaust header
i want loud and fast :DD (No engine swaps or turbo)
i heard that i can take head out of a car with d16y8 (if i remember right (or b16y8))
and put that on my d15z6
i want somthing plug and play.
Old Feb 18, 2014 | 04:01 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: D15Z6 upgrade?!?
You aren't going any faster with that motor within your limitations, period. Yes, you can drop a Y8 head on your motor fairly easily, but you'll also need a new ECU. A stock P2P ECU (stock D16Y8 ECU) should be able to run that, as well.
If you actually want to be faster, a swap or FI is a necessity. Period.
Old Feb 18, 2014 | 04:04 PM
B_Swapped93's Avatar
Hey OP
Old Feb 19, 2014 | 08:22 AM
VeganEJ8's Avatar
read faqs... also there is no such thing as a b16y8... you have a sohc d series. You won't get much power out of a header. d series don't gain as much powers with bolt ons as other engines.
Old Feb 19, 2014 | 12:39 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Not sure why one would need a Y8 ECU to use a Y8 head.
Anyway...OP....D series engines don't respond well to bolt on mods. The best/cheapest mod for a D series is a B series.
Old Feb 19, 2014 | 01:09 PM
ej1b18c1's Avatar
OP, you can make it loud but without any forced induction on a d-series it wont be fast. Then again, it all depends what you clarify as being fast.
Old Feb 19, 2014 | 01:18 PM
crazyhouse2011's Avatar
Originally Posted by benderinn333
D15z6
Nobody caught this yet? OP there is no D15z6 engine. There's a D16Z6 though. And you want you're car loud and fast? straight pipe the exhaust and strap on a 75 shot of nitrous. You'll get about 3000 miles out of the engine before it explodes.
Or you could do a long, very expensive N/A build that would be very unrewarding.
Old Feb 19, 2014 | 01:51 PM
NotARaCist's Avatar
There you go talking when you have no clue what you're talking about again. There is a D15Z6. It's a European VTEC-E motor. Seriously, stop posting if you have no clue what you're talking about.
Old Feb 19, 2014 | 06:47 PM
OP is in america?
Old Feb 19, 2014 | 06:51 PM
NotARaCist's Avatar
OP is in america?
And you know this...how? He never said where he's from. Aside from that, there are PLENTY of places online where you can buy CDM, EDM, JDM, and [X]DM motors to install. You're backpedaling.
Old Feb 20, 2014 | 02:09 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Swap or turbo, that is all.
Old Feb 20, 2014 | 02:10 AM
doctorake's Avatar
Community Builder
Old Feb 24, 2014 | 09:13 AM
Frostbite0180's Avatar
yeah its a d16z6
Old Feb 24, 2014 | 09:35 AM
NotARaCist's Avatar
Originally Posted by Frostbite0180
yeah its a d16z6
Old Feb 24, 2014 | 09:59 AM
92_civic_eg's Avatar
Just like what some other people said u need to swap or turbo, I say turbo because turbo is the ****..
Old Feb 24, 2014 | 03:34 PM
Supercharger doe.
Or a 100 shot of NOS. OP just make sure you don't blow the welds on the intake
Old Apr 26, 2019 | 10:14 AM
Hasan Khurshid's Avatar
Default Re: D15Z6 upgrade?!? I want loud and fast :DD
There is a D15z6 for europe market and I am using it. You can get the info on wikipedia also.
D15Z6[edit]
  • SOHC VTEC-E
  • Found in:
    • 1995–2000 Honda Civic 1.5i LS (European Market)
      • Displacement : 1,493 cc (91.1 cu in)
      • Bore and Stroke : 75 mm × 84.5 mm (2.95 in × 3.33 in)
      • Rod Length : 137 mm
      • Compression : 9.6:1
      • Power : 114 PS (84 kW) at 6,500 rpm
      • Torque : 99 lb·ft (134 Nm) at 5,400 rpm
      • VTEC Switchover : depending on load, max ~3,500 rpm in 5th gear
      • Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on engine speed)
      • Fuel Control : OBD-2a PGM-FI MPFI
      • Ecu Code : P2Y
      • Head Code : P2J
      • Redline : 6,800 rpm
      • Fuel cutout : 7,200 rpm
Old Apr 26, 2019 | 10:22 AM
Freedo_Civegra's Avatar
Dang that was brutal
Old Apr 26, 2019 | 04:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Sometimes the truth hurts.
Old Apr 26, 2019 | 08:36 PM
Toxic3469
Oct 4, 2012 03:44 PM
908civic
Mar 15, 2010 08:34 PM
Stangracer85
Oct 26, 2009 06:03 PM
jr_deleon
Nov 13, 2008 11:29 PM
jayjay0718
Jul 29, 2006 08:01 PM
