95 eg hatch ebrake sensor wire?
I'm hooking up a turbo timer. Took off my center console and there's no wire on or around my ebrake for the sensor. Searched were to tap it out and can't find anything. Thanks in advanced for help.
It runs to and through the under-dash fuse box and then to the gauge assembly; so, there are several places to tap into.
One place is at a 14P gray connector located behind the left kick panel (it is lower down, lower than the fuse box); the grn/red wire is at pin 9 on the male terminal connector side, on the female connector side it will be a red/grn wire instead.
