What is this called?
Yes they are but you'll need a spanner wrench to be able to adjust the height.I would take a good look at them though the adjustment rings should sit flat and not to the side the way they are.
spanner nuts are crooked anyways. they prolly wouldnt adjust from being jacked up(threads)
but you can always use a flathead and a hammer to get the spanner nuts loose then jus tap them up or down
