need help..cylinder head plug and camseal
Old Feb 18, 2014 | 12:25 AM
ribal_gh's Avatar
Default need help..cylinder head plug and camseal
Hello,
My b16 engine is leaking from the cylinder head cap, but while searching i found that there is also cam seal but couldnt tell if they are the same.
Please advise.
I have already pirchased an oem head plug, but i need to know if i should remove the valve cover in order to replace it or simply it pops in without removing the VC?
Old Feb 18, 2014 | 01:11 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: need help..cylinder head plug and camseal
http://importnut.net/b-series-cam-seal-install/
Old Feb 18, 2014 | 05:45 AM
ribal_gh's Avatar
So the cam seal and cylinder head plug are the same!
Just the aftermarket one is called cam seal and manufactured in a diffrent desgin?
Old Feb 18, 2014 | 06:06 AM
kyden's Avatar
yes they are the same. the aftermarket one is less susceptible to leaks, since it has 3 o-rings. the plastic one with the single o-ring i have not run into an issue with yet. the one that sucks is the all rubber one that came on earlier gsr.
Old Feb 18, 2014 | 07:14 AM
ribal_gh's Avatar
Ok great, thanks
Finally i need to know if i can just pop it or i need to follow the same procedure as installing aftermarket cam seal.
Old Feb 18, 2014 | 07:41 AM
NotARaCist's Avatar
I never narc'd on nobody!
You have to remove the valve cover, and apply HondaBond to the new one.
bigsnorlax
Jan 19, 2010 09:04 AM
ThatGreenGsr
Sep 14, 2008 07:45 AM
speed84
Sep 6, 2007 06:33 PM
VacantBanana
Jun 8, 2004 10:04 AM
