93 del sol brakes
Old Feb 17, 2014 | 07:48 PM
srbr's Avatar
Default 93 del sol brakes
I changed rear brake pads on my 1993 Del Sol SI and a piston dust seal (had piston out of bore)-brake pedal went to floor after trying to bleed brakes (no air in lines)-replaced master cylinder-pedall stil goes to floor and no air is in lines at bleeders and no air at master cylinder lines-never seen anything like it-help?
Old Feb 17, 2014 | 09:20 PM
B_Swapped93's Avatar
Default Re: 93 del sol brakes
did you do them in the correct order ? also have you looked for any leaks ?
Old Feb 18, 2014 | 06:57 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Look for a leak where you replaced the seal and elsewhere.
Bleed the brakes with the car turned on. Bleed thoroughly. I use the bottle and vacuum hose method. It's better and faster than the pump and hold method that cavemen developed before the ice age when you could get a brontosaurus burger for 5 cents.
Check for a stuck caliper pin.
Usually do these steps before replacing a master cylinder that worked fine before.
DelsolVted
11
May 7, 2011 11:33 AM
ismael-robert
Suspension & Brakes
Apr 16, 2009 05:56 AM
xerokill
Feb 24, 2008 09:23 PM
WRTEG
Jan 18, 2006 11:59 AM
rawkus
Dec 19, 2004 09:59 PM
