Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda Accord transmission trouble
Old Feb 17, 2014 | 11:47 AM
AstroBoy10's Avatar
Icon3 2004 Honda Accord transmission trouble
I have a 2004 Accord. while traveling for about 2+ hours and I have to admit, I was pushing it, averaging about 80 mph, when all of a sudden, I felt this lurch, if you will, and then I started losing power. I saw the speedometer start to decrease, so I started to pull over and by the time I did, it kicked back in and I was driving again. After I got off the freeway and came to a 4 way stop, the car was idling fine. As I started to proceed, when the car got up to about 20-25 mph, I felt it surge again. It did this two more times. When I got home and in the driveway, I turned the car off and waited a few minutes before starting it again. Leaving it in park, I depressed the accelerator and as it approached 20-25 mph, the needle started surging up and down, as if I was feathering the accelerator. Has anyone ever dealt with this type of problem? Could it be a sensor, a module or a relay? Wondering what to do.
Old Feb 17, 2014 | 12:00 PM
AstroBoy10's Avatar
Default Re: 2004 Honda Accord transmission trouble
Me too.
Old Feb 18, 2014 | 03:57 PM
furious94ls's Avatar
Is there a CEL on? D5 light flashing? Check the fluid, and it's condition. Most likely it's the common internal failure. Some people try the 3x3 drain and fill, and change the 3rd and 4th gear pressure switches along with the inline filter.
Old Feb 22, 2014 | 03:22 PM
shophound's Avatar
05 accord replacing timing chain @ water pump can't get crank bolt out is it Rt or LT threaded
Old Feb 23, 2014 | 07:44 PM
Bakuryu06's Avatar
Automatic?
Dusty Cross
Honda Accord (2013 - 2015)
Aug 18, 2018 01:43 PM
Ely94
Oct 2, 2017 03:53 AM
clifftbrd
Jul 11, 2014 01:40 PM
jiten42
Jul 4, 2003 07:34 AM
