Suspension & Brakes Theory, alignment, spring rates....
Need help choosing a brembo caliper
Old Feb 17, 2014 | 11:46 AM
arbys Eg6's Avatar
Default Need help choosing a brembo caliper
Alright so I was going to buy an endless brake kit a few days ago until I looked into Brembo calipers. I then decided it would be sick to get my hands on a set of Nascar brembos or something close. I am stuck because there are a few good options in which I will state here. Basically I want to know what any of you have had experience with. Also which would you go with and if not any of these then do you have a suggestion. I am going to have to fit them under a 16in Mugen mf10, and will have custom rotor hats made and want to try to keep the spacers needed to a minimum.
Xa69404
Xa4c614
Xa4c613
Xa4d303
Xa4d304
Xa3a444
Xa3a443
Xa2e504
Old Feb 18, 2014 | 01:25 AM
Kozy.'s Avatar
a.k.a. Komodo
Default Re: Need help choosing a brembo caliper
Assuming this is going on an EG6 with 240mm rear brakes?
You realise that Xa3a444, Xa3a443 and Xa2e504 are rear calipers, and not suitable for the front of your car, yes?
The Xa69404, Xa4c614, Xa4c613, Xa4d303 and Xa4d304 are all front calipers but with 44/38mm pistons. These is too big for your car, especially if it is going to be used with large rotors. You ideally need to be looking for somewhere around the 36/40mm range.
Old Feb 20, 2014 | 10:02 PM
arbys Eg6's Avatar
Bump
Old Feb 23, 2014 | 10:27 PM
arbys Eg6's Avatar
What is Rcrew using to fit under 15s? I ideally need a caliper around the same specs as what they are using.
Old Feb 24, 2014 | 08:41 AM
cruizinmax's Avatar
Have you seen how wide NASCAR brembos are? The brake pads are incredibly thick.
Old Feb 24, 2014 | 07:50 PM
arbys Eg6's Avatar
I believe r crew is using nascar rears and fitting them under 15s so I know it's possible. But your right the front nascar nickels would need like a 40mm spacer. I'm talking something like a 26mm piston. Ones your talking about are like 38/44mm
Old Feb 9, 2015 | 08:42 AM
oldschooljdm's Avatar
I have a set of XA69404 and XA69403 for sale, I was going to use these on my S13 project but gave up on the car, so if you want to buy a set LMK.
LOW_ONBILLETS
Honda CR-V & Element
Jun 12, 2011 03:50 PM
Catscan
Jun 12, 2006 09:38 AM
gogordo
Sep 27, 2004 07:31 PM
PinchE NegRo
Mar 3, 2003 07:13 PM
