Spark plug burned?
Old Feb 16, 2014 | 10:18 PM
nicknack25's Avatar
Default Spark plug burned?
Just wanted to get some input on this. All 4 spark plugs the same. Not sure if this means it needs to be changed out, if somethings wrong, or if its just normal. I don't really remember when i first put these in. I would probably say around 20k miles on them. And arounds 45k on these autozone 7mm wires. The tip was normal.
Also this is a 01 gsr
Old Feb 16, 2014 | 10:32 PM
B_Swapped93's Avatar
Default Re: Spark plug burned?
you've got some oil leaking into the plug well's grab the seals from Honda and clean out the plug wire with some brake clean. nothing to worry about I had that then I realized the seals were leaking.
Old Feb 16, 2014 | 10:48 PM
nicknack25's Avatar
Ahh, I see. Thanks for the quick reply!
702SI
Dec 5, 2014 03:59 PM
crashsvg
Dec 1, 2008 05:51 PM
CR91X
May 24, 2008 04:13 PM
5lugSlug
Jul 19, 2004 07:34 PM
ptran
Jun 17, 2004 06:33 PM
